      09-11-2012, 08:37 PM   #1
dsgrillot
dsgrillot's Avatar
Drives: 2008 Z4M Roadster
Vibration when braking...warped rotors?
Help please. I get a lot of vibration in the steering wheel when braking. Still have plenty of pad life left. The dealer says the rotors are warped. Only 25,000 miles on the car...warped rotors? Really?
So how do I check them myself ? If they are warped, how do I replace them and should I use OEM or some upgraded rotor?
Any advice is appreciated.
M School
      09-11-2012, 08:42 PM   #2
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
More likely pad deposits. While it's not unheard of, warped rotors is pretty uncommon with our floating rotor design.
You could always try the bedding procedure and see if that helps.
      09-11-2012, 08:51 PM   #3
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
Dealer tried to tell me I had warped rotors as well when I went in for control arms.
This was right after my first track day where I took it easy and broke early on alot of turns (rain).
Anyways, I told them a BS excuse that I'd replace them later, got the car, re-bedded my pads and it's perfect again
      10-25-2012, 01:37 AM   #4
MikeRua
MikeRua's Avatar
South Africa
Drives: 2009 Z4 M Coupe
aaaah some thing I can relate too, I had this issue - I have very low Km's on my Zed, and was concerned after getting the Rotors replaced 3 times under warentee, I did not understand why so soon, then I had the wheels checked and found that they where the cause, get your wheels checked out first.
      10-25-2012, 05:01 AM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ this....
Before you do the bedding procedure, it's best to clean the existing deposits off of the rotors.
Use some brake cleaner & an aggressive scour pad.
      10-25-2012, 02:21 PM   #6
mhughett
Drives: 2007 Z4 M Coupe
^ this....
I've had significant problems with brake vibrations and while my car was under warranty, rotors and pads were changed out by the dealer about 6 times. I know the rotors weren't warped and I suspected somehow I was getting pad deposits. So after the warranty expired I tried inTgr8r's method above but it didn't work. I finally got the problem fixed by using the method recommended on Stop-Tech's website--that is to buy some aggressive track pads and "clean the rotors" using their documented technique. It's similar to bedding in the pads except you do NOT want the pads/rotors to get so hot that the pad material transfers to the rotors. This involves a lot of driving with no braking in between the hard stops to allow the rotors to cool down. You only want to use the abrasiveness of these pads to clean the rotors. It's kind of like putting the rotors on a lathe except you don't have to take them off the car. Stop-Tech recommended Hawk blue pads so this is what I used. This method worked for me and I no longer have these vibrations and if they come back, I know how to deal with them.
      10-25-2012, 02:31 PM   #7
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ yeah, that's really the best way if you can put your hands on some aggressive pads.
      10-29-2012, 08:03 PM   #8
Alexander
Mad tyte EuR0 style boooi <--- Joke
Alexander's Avatar
Drives: E30, E85, MKVI
Sounds like it.
      10-29-2012, 08:32 PM   #9
Finnegan
Finnegan's Avatar
Yup, Hawk Blues are the next best thing to sandblasting or a lathe.
