      11-28-2014, 08:29 AM   #1
jra
Drives: 2005 z4
Wheel help
Bent a wheel so currently on a front spare...looking at a set of 9.5 square zcp's I know I can get the rears to fit but what about the front on a 235 or 245? Have camber plates
      11-28-2014, 05:36 PM   #2
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Do you have the offset on the 9.5" you're looking to run up front? Sorry, not too knowledgeable on the ZCP wheels. 9.5" can work up front with those tire sizes so long as the offset is correct.
BTW I kind of like the 5-spoke / 6-spoke stagger you had going on
-Matt
| Z4M Build Thread | @violetnites | flickr |
      11-28-2014, 06:14 PM   #3
jra
Drives: 2005 z4
Yeah I really like my ssr comp h's but impossible to find...the offsets for the zcp wheels are et 27
      12-01-2014, 05:27 PM   #4
tiltmode43
I plead the 5th.
tiltmode43's Avatar
You can fit a 9.5 ET27 up front, especially if you're willing to dial in some camber. Depending your tire size and how much camber you go with, fender roll may or may not be required.
This is @3002 tii car running 17x9.5 et30 w/255's up front:
@all4bespinnin car running 18x9.5 et22 w/255/35 up front:
EAS car running 18x9.5 ET22 w/265/35 up front (with lots of camber):
Hope that helps!
-Matt
