      11-23-2014, 10:17 PM   #1
Varinn
Drives: 2007 Z4MC
Is it spring yet? (V810 content)
Planned on getting a set of Apex ARC-8's for my Z4MC from damn near the day I bought it but opted for a different look. A few months down the road and after looking into a multiple other (equally nice) options a member here posted these and it took a couple days to fall for them, but fall I did. It's winter here now and I don't have the rubber yet, but I was bored and couldn't leave them boxed up after picking them up yesterday so I decided to mess around and snap a few pictures.
First impressions are promising as they all look great with a brilliant finish. Both the VMR and OEM bmw caps fit snug, the weights seem accurate.
Front 18x8.5 et35 (~20.5lbs)
Rear 18x10 et25 (~21.5lbs)
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic)
2008 KTM SuperDuke 990
2007 Z4M Coupe (#1026/1815) SOLD
      11-23-2014, 10:40 PM   #2
NickyC
NickyC's Avatar
17424
Wow those are nice! They remind me of the CH-Rs, a very good thing.
      11-24-2014, 07:21 AM   #3
Arick
Drives: Porsche GT3, BMW X6M, Tesla M3
Very nice looking wheels
      11-24-2014, 01:08 PM   #4
Varinn
Drives: 2007 Z4MC
Thanks for the comments, I'm sure most of you understand the pain of not being able to install new wheels on the car for a few months. I need to find a way to tuck the boxes away otherwise Im not sure how I can survive the winter when I can keep staring at them
      11-24-2014, 01:35 PM   #5
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Can't wait til we see these mounted. Thanks for sharing, Kyle!
      01-18-2015, 11:37 PM   #6
Varinn
Drives: 2007 Z4MC
EDIT: wrong thread for this
      02-18-2015, 05:17 PM   #7
Hujan
Hujan's Avatar
Drives: M3
Any updates on these wheels? I am thinking of putting the exact wheels on my Z4.
      02-19-2015, 11:05 PM   #8
Varinn
Drives: 2007 Z4MC
Yup had them mounted for a while now, decided to do a winter wheel swap despite the temps outside.
18x8.5 et35 w/ 245/40-ZR18 Michelin PSS @ -1.50° camber, minor rub full left lock
18x10 et25 w/ 275/35-ZR18 Michelin PSS @ -1.00° camber, zero rubbing. Planning to return to stock camber soon, drives great in straight lines but I think stock would be better for hard corners when summer comes.
      02-20-2015, 06:53 PM   #9
VMRWheels
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
^ So good
      02-20-2015, 08:07 PM   #10
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
What is stock camber value? More negative camber will give you better cornering grip
Where are you rubbing up front? Inside or outside? If you're rubbing the outside then going back to less negative camber will make it worse.
FWIW, I have 18x9 ET37 with wide-running 245/40/18 tires up front and I don't rub at all even during hard cornering at autocross. I added $5 camber washers so my camber is at -2.7*
      02-20-2015, 08:57 PM   #11
Varinn
Drives: 2007 Z4MC
As far as I can tell it's rubbing on the inside front edge of the left tire against the little window for the headlight access. This seems to be an issue with the plastic liners on my car, I had identical problems when attempting to install 12.5mm spacers with the stock wheels/tire sizes.
I replaced my RTAB's and installed the limiter kit just before putting the new wheels on. When I had the alignment done I asked them to put it to stock specs in the rear and pull the pins up front to dial in max negative camber. I picked the car up and found they had decided to go against what I said and put the rear at -1* because they felt it would be better with the wide tires. I didn't have time that day to leave the car with them to correct it so I've kept it that way for a bit now. It handles great in straight lines (tramline's like a mother though), but I actually find the overly grippy straight lines makes it a bit less fun. I'd rather have the car set up for maximum cornering grip and the occasional wheelspin in the straights when I want it, so back to stock in the rear. I will be keeping the negative up front.
They gave me the option to try it out for a bit and if I didn't like what they did I can return to get it adjusted, so I am planning to do just that next weekend. Here's my alignment sheet with before/after and stock reference.
      02-22-2015, 10:54 AM   #12
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
They look great!!
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      02-24-2015, 09:30 PM   #13
Hujan
Hujan's Avatar
Drives: M3
Looks good, OP!
If you have a chance, I would love to see some side shots (perpendicular to the car) in sunlight.
      02-27-2015, 01:51 PM   #14
Varinn
Drives: 2007 Z4MC
Originally Posted by Hujan View Post
Looks good, OP!
I've been meaning grab pictures in the daytime soon, but at the moment I'm stuck with the car in pieces because of a water leak. As soon as I get the damn thing sealed up and re-assembled I'll head out to get some more.
      03-10-2015, 01:05 AM   #15
Hujan
Hujan's Avatar
Drives: M3
Sorry to hear about the mechanical issues. Good luck getting them sorted out. Looking forward to the daylight pics when you do!
      03-13-2015, 07:19 AM   #16
Slalom
Slalom's Avatar
Drives: 04 Z4, 18 X3 M40i
2004 Z4  [0.00]
2018 BMW X3 M40i  [10.00]
Damn, I wish that it were spring. Pothole season here. Lots of blown tires and bent rims around here. My Z4 and M3 are staying in storage for another month.
