      10-01-2014, 08:14 AM   #1
LouZ4M
LouZ4M's Avatar
Drives: 06 Z4M Coupe
Direzza ZII Star Spec with Stock Wheels
I have heard great things regarding the Direzza ZII Star Spec. I would like to purchase them for my M Coupe, but the rears do not come in the OE Size.
Has anyone installed a set on the stock wheels? If so, what size did you purchase. Car is a weekend warrior with the occasional track day.
I don't know much about tire sizing, so I appreciate the help.
OE Rear Size: 255/40-18
Here are the sizes listed on TireRack:
225/40R18 88W
225/45R18 91W
235/40R18 91W
245/40R18 93W
255/35R18 90W
265/35R18 93W
275/35R18 95W
285/30R18 93W
      10-01-2014, 08:50 AM   #2
dorifto88
Drives: 88 Nissan Pathfinder
Foeoe wheels I would suggest 235/40 and 265/35
      10-01-2014, 09:55 AM   #3
LouZ4M
LouZ4M's Avatar
Thanks. Have you used this fitment before? Just want to make sure there is no rubbing or performance issues. Appreciate the help.
      10-13-2014, 08:54 PM   #4
omglukewtf
Drives: 2008 Z4 M Coupe / 2011 E93 M3
I'm running 245/40R18 and 275/35R18 with the ZII Star Spec's on the Stock wheels with no rubbing. I also picked this size based on a number of other people running the same size for track use.
Edit - I'm also using Turners camber shim kit for -2.7º in the front with no rubbing.
      10-13-2014, 10:55 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Both sizes will work with this particular tire on the stock wheels. The 245/275 is a much larger tire though, and, at the absolute end of the size range. In my experience, and using a pyrometer, the 235/245 may actually supply a better contact patch with the stock wheel sizes. The 235/265 size is a smaller diameter tire than stock, still within the 3% ABS/DSC effective range, but it gives a bit more torque to the rear wheels (and a stiffer sidewall than the larger tire).
