07-18-2008, 11:31 PM | #23 |
Rep 2,410
Drives: E30 M3 Cecotto, F85, G05, G07,
I think the plastic was to help prevent excess water and debris from getting in the wheel well and causing a liability for BMW.
I took mine off.
07-21-2008, 12:15 PM | #25 |
1821
Rep 5,337
07-21-2008, 06:39 PM | #26 |
Rep 212
Here's my 2 cents:
BMW usually designs parts like this for a reason. I suspect the "wind break" is placed there for the following reason: Fluid theory works on the concept known as Bernoulli's Principle: (http://theory.uwinnipeg.ca/mod_tech/node68.html) According to this theory, when velocity increases, pressure decreases. For example, turn on a garden hose and let it run, put your thumb over 1/2 of the outlet, and the water will shoot out at a higher velocity (the pressure created by the blockage immediately decreases when the water gets past it, as a result, the water speeds up). I suspect that there might be a BMW engineer or two who might know about this principle of fluid theory. Just as your thumb speeds up the water, the "wind break" in the cooling duct speeds up the airflow, thus making it more effective as a brake cooling device. By cutting out the break and opening up the hole, you probably decrease the effectiveness of the duct. |
07-22-2008, 08:35 AM | #27 | |
My favorite sign.
169
Rep 4,333
In incompressible flow, when you have a blockage like is present in the duct, you'll have stagnation in front of the blockage, and scattering behind it. So...basically you're wrong, but good try!
07-22-2008, 05:48 PM | #29 | |
Rep 4,726
BMW does this with a lot of it's cars, that is covering the brake ducts in the US. Be glad they were not fully covered and just half covered. As dammit said, only an idiot would just put a flap in the way to "increase velocity" If they wanted to do that they would slowly shrink the diameter. 90% of US drivers wont even need any brake cooling at all, but you need that full duct if your stopping from 150 on the autobahn, and you sure as hell need it if you're at the track.
07-22-2008, 06:19 PM | #30 |
1821
Rep 5,337
07-22-2008, 06:26 PM | #31 | ||
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
07-22-2008, 06:29 PM | #32 |
Rep 5,069
So why add it? No speculation, I really would like to know. My gut tells take it off you don't need it, but I don't like to assume I know more than the engineers working on certain projects intimately.
07-22-2008, 06:51 PM | #33 | |
My favorite sign.
169
Rep 4,333
07-22-2008, 06:53 PM | #34 |
My favorite sign.
169
Rep 4,333
I thought about it more today, I think the reason its there is to prevent larger debris from getting into the suspension, brakes, and other parts in the wheel well. The water explanation doesn't make a whole lot of sense.
07-23-2008, 09:15 AM | #36 |
Rep 2,128
I propose that going forward the default explanation for any inexplicable discrepancy should always be "Because BMW wanted to keep the Z4M from out-performing the M3." Doesn't matter if it's true or not, if it makes sense or not, or if we've got proof - we should always just say that. Will anyone second the motion?
07-23-2008, 10:07 AM | #37 | |
My favorite sign.
169
Rep 4,333
07-23-2008, 12:52 PM | #38 | ||
1821
Rep 5,337
I may need to do some research on this, but I think the E85/E86 Ms don't come with the rainy brake pre-wipe that's part of newer DSCs. |
07-23-2008, 01:30 PM | #39 |
Rep 2,128
I seem to remember that feature as part of DSC+, which also added the hill-hold (drive-off assist) feature. So I'm 99% sure we've got that. Which is surpising because BMW wanted to keep the Z4M from out-performing the M3.
08-17-2008, 07:22 PM | #42 | |
Rep 120
Anyways, I cut my ducts out this morning. If I spin out next time I do full panic stop in the rain I'm suing Zpost |
08-17-2008, 10:29 PM | #43 |
Rep 746
Drives: 2009 Honda Civic Si
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD 09' 2.0 Polished Metal Metallic Honda Civic Si - Current |
08-18-2008, 08:40 AM | #44 |
My favorite sign.
169
Rep 4,333
We'd just have to chalk it up to driver error
