      04-27-2015, 01:21 PM   #1
Ranger_Vet68
Ranger_Vet68's Avatar
Drives: 2003 Z4 3.0i E85 Roadster
Rag Top Care
OK, No more "Car Washes" any longer. Just had the car full detailed, and will have the car hand wash until I pick up another one. Question. After the Detail, I hear that using the "Meguiar's" CONVERTIBLE & CABRIOLET CLEANER is the best way to go.....Suggestions?? Also I was told that when I have my care hand washed, to leave the top alone. Meaning not getting the top wet because of it becoming "Damp". Is that correct????
Thank You.
      04-27-2015, 02:15 PM   #2
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Do you not drive the car in the rain? The top getting damp shouldn't be an issue. I would be careful of what kind of soap you are using on the paint coming in contact with the top. Some soaps might eat away at the protection you put on the fabric
      04-27-2015, 02:45 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Look for "Rag Top" products for cleaning/conditioning the top.
They worked great when I had my roadster.
      04-27-2015, 04:20 PM   #4
Ranger_Vet68
Thank You for the info......
      04-27-2015, 05:12 PM   #5
Steeler
Steeler's Avatar
2428
This might sound a little stange but I use a lysol handiwipe, squeeze most of the liquid out and wipe the top working side to side across the fabric.
The wipe leaves lint behind but a rolled up piece of duct tape works well as a lint catcher.
To seal it I use 303 fabric protectant.
      04-27-2015, 08:08 PM   #6
Ranger_Vet68
Just best to use a lint roller...That's what I use...
      04-27-2015, 08:12 PM   #7
Ranger_Vet68
Nate, Your quite correct about the soap that is being used. I just tell them to stay away from the top with the soap. But here's another question. If they just spray the top of the car with water, and then have then Vacuum the water off the top. That could not hurt the top...Correct??
      04-28-2015, 03:26 AM   #8
Nate4641
Nate4641's Avatar
No, that shouldn't be a problem. Don't be afraid of the top getting wet, it was made to be outside. If you look at the pic in my signature my car is caked in road salt, these cars aren't fragile. Mostly when it comes to washing I would be careful not to get too much soap on the fabric and do not use a power washer on it (learned that lesson with my old miata). Even if soap does get on the fabric, just rinse it off.
If you notice the top soaking in the water more than beading it off, let the car sit in the sun for a little bit to dry and add some more protectant. It is normal for the fabric to absorb some water and it's nothing to worry about. You definitely do not want to put the top down if it is wet though, that can cause mildew.
      04-28-2015, 02:16 PM   #9
Ranger_Vet68
Sounds good to me...And I would never want to place the top down when its wet. That in it's self can be the worse thing to do...
      04-28-2015, 02:40 PM   #10
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
I usually just spray the top with water only. Every few washes I use raggtopp products with a horse hair brush. She's holding up well
      04-28-2015, 03:48 PM   #11
TennesseeZ4
TennesseeZ4's Avatar
Drives: 2003 Z4 3.0i; six speed manual
Ragg Topp
+1 on the horse hair brush and Rag Topp cleaner and sealer. Works great, I do mine about every two years.
      04-28-2015, 05:44 PM   #12
Ranger_Vet68
Yep, I just bought that stuff and will use it. Plus putting on that Protective coat so when water is on the top, it just turns to beads of water and rolls right off...
      04-29-2015, 05:11 PM   #13
imz4n
imz4n's Avatar
Drives: 2006 3,0 si TITANIUM SIlVER
I use a soft nylon brush ( stiffer than a shoe buff brush, but, not a kitchen brush ) to remove heavy dust and dirt ( brushing in the direction of the grain of the canvas material ) then rinse the top with water and brush and rinse again. I never use soap on the top ever. Clean and treat the top once per year. Just saying
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
