04-11-2015, 04:10 PM | #1 |
Rep 23
New tires and rims on my 2.5
I put new rims and tires on my 2004 2.5 . Their Nitto 555 extreme 265 35 on the rear and 235 40 on the front . I put some niche misano rims on them . 18x9.5 on the rear and 18x8 on the front I put them on two days ago and since I've been using them I feel like I have to hit the gas pedal a little more like I guess a light loss in power? Is that normal? Are the tires too big for the vehicle? Also when Im going let's say 20 mph or more and I hit he breaks like slowy leading up to the stop , I hear a squeak, or some sound from the brakes . It's not really that loud , but I've noticed it . Is any of this normal? Should I be concerned? Thanks!
04-12-2015, 12:13 AM | #3 |
703
Looks like you should be running 235/35 and 265/30; not 235/40 and 265/35. The sizes you're running are larger than stock diameter by a bit over 2%. That's reduced your torque to the wheels a bit which may make the car seem sluggish. The /35 /30 sizes decrease diameter by at bit over 1%, increasing wheel torque.
Aside from painting the calipers did you change anything? You can try different sizes here. http://www.1010tires.com/Tools/Tire-Size-Calculator Edit: light squeaking could be from using the brakes lightly all the time. You could try re-bedding the brakes and see if that helps. Nothing to really worry about as long as there's sufficient pad material left. |
04-12-2015, 12:57 AM | #4 |
Rep 118
The new setup is probably a bit heavier. The overall diameter change won't make that big of a difference. It's not that much bigger than stock. Tires are usually fairly close in weight(similar size), the wheels can be night and day.
04-14-2015, 03:49 AM | #8 |
1621
Rep 4,294
sure, no worries, get a photo bucket account (free) upload your pics there, then when adding a post, select advanced and then click on the little pic icon, add the web addy of the pic and Bobs your uncle ;D
Powered by |
04-25-2015, 11:52 PM | #9 | |
Rep 23
04-26-2015, 06:48 PM | #10 | |
Rep 23
04-27-2015, 01:40 PM | #11 | ||
703
