      01-27-2010, 05:20 PM   #1
Fed
Drives: 2015 Alpine White M4
Diff Problems?
Has anyone had Diff problems with their Z4M? I have a 2006, that I bought new, and has been babied since purchased, no clutch drops, burnouts, track time. at 40K miles started hearing a metalic grinding/humming when driving that got louder as the car sped up. Took it to the dealer who said it was brake noise and normal on the car. Took it to another dealer who drained the diff fluid and found metal in it, and replaced it under warranty.
I'm trying to find out if this is a common issue on these cars? I'm still dealing with BMW to fix my squealing brakes which they also tell me is normal.
      01-28-2010, 12:26 AM   #2
hansaysso
hansaysso's Avatar
Drives: 07 Z4MC, 93 RX7 FD3S
how often did you change out the diff/tranny fluid? bmw tells you that their diff/tranny fluid doesn't need to be changed out after the 1.2k mile break in service but thats a joke.
      01-28-2010, 11:00 AM   #3
DarkstarZero
DarkstarZero's Avatar
Drives: Daytona 95 M3, X7 M50, e92 M3,
You should replace your break pads with something different anyways. You can get really good street pads that are better than the OEM ones, don't produce break dust, and don't squeel for around $100. They're not hard to replace on your own either.
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center!
Enter Referral ID: 420186
      01-28-2010, 06:19 PM   #4
trsbmw
deft danish devil
Drives: BSM E86 M-Cp, LMB 335d M-Sport
2007 Z4 M Coupe  [0.00]
This is incorrect. BMW service schedule for diff fluid (and transmission fluid, for that matter) change is at every Inspection II. (which should be about every 55-60k according to the Service Interval Indicator)
I myself think it should be sooner.. (I plan to change at 15k and have a used oil analysis performed to confirm status of the old oil)
