      11-23-2012, 05:18 AM   #23
pal
pal's Avatar
433
Drives: Z4 M Coupe
I have the 4-pot kit all around with Brembo LCF 600+ fluid, Hawk DTC-60 pads up front and HT-10s out back- love the setup. Better brake feel, modulation, cooling and lower pedal pressure.
Front weights:
      12-11-2012, 10:41 AM   #24
Shaung
Drives: E92 M3
I just want new 4 piston calipers...
      12-11-2012, 11:24 AM   #25
Beedub
4pots are more than enough imo!!!
      02-12-2013, 04:55 AM   #26
RSPINAJR
@rspinajr
RSPINAJR's Avatar
Drives: 2020 F87 M2 CS
Are all you guys on stock wheels? Im looking for a brake upgrade as well but rather not change the wheels.
Pal from Jersey?
      02-12-2013, 07:36 AM   #27
Mirko
Mirko's Avatar
Pal from Jersey?
I am on stock wheels for winter with the 6/4 setup. In the front you need a 12.5mm spacer. The rear is fine. I have camber plates and am lowered slightly so I don't rub as bad as others might with stock wheels but there are a few times I can hear some rubbing in corners.
      02-13-2013, 07:05 AM   #28
RSPINAJR
@rspinajr
RSPINAJR's Avatar
Thanks Mirko You have any pics with your winter setup?
      02-14-2013, 03:01 AM   #29
tikamak
Lebanon
58
Anyone heard or using XYZ brakes? http://www.xyz-racing.com/
It's a racing BBK and i reckon it's pretty high quality. My friend has an HPF stage 2 M3 and that BBK can hold the car down like nothing else. we haven't tested brake fade under track conditions but these XYZ brakes seems to be used in competition racing.
I am thinking of purchasing the 355x32 6POT all around BBK brakes.
      02-14-2013, 07:07 AM   #30
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
2006 Z4 M Coupe  [0.00]
A friend has a 330mm 6 piston XYZ kit on the front of his Audi TT 2.0t but doesn't actually uses them in anger.. They look decent quality for the money though.
      02-14-2013, 07:19 AM   #31
CJW2OO4
CJW2OO4's Avatar
what kinda pricing are we looking at with the xyz kits?
      02-14-2013, 08:11 AM   #32
tikamak
Lebanon
58
Cheaper than stoptech, that's for sure. 2500$ for a 6-pot 355mmx32 Floating with high quality pads.
      02-14-2013, 08:21 AM   #33
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
In Europe it's about €1500 for the front 6pot 355mm kit. Not sure about North American pricing...
      02-14-2013, 10:17 AM   #34
CJW2OO4
CJW2OO4's Avatar
Damn I wouldnt need a 6pot kit for myself. I wonder if we could get a price list?
      02-14-2013, 10:55 AM   #35
tikamak
Lebanon
58
HYG: http://www.xyz-racing.com/brake1.html
      02-14-2013, 11:04 AM   #36
CJW2OO4
CJW2OO4's Avatar
thanks. Looking for a BBK kit for my Z4 (non M coupe) I dont need crazy performance as the car is my daily. I will probably need to change the brakes along with the calipers soon so I am looking at my option. Car has over 105k on it.
      02-16-2013, 08:54 PM   #37
Mirko
Mirko's Avatar
12.5mm spacer in the front. Camber plates and lowered with KW V3 on highest setting. If you want better angles let me know. I will have to dig up my alignment specs.
      02-21-2013, 03:23 AM   #38
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
our oem brakes are good, but why couldn't bmwM give us the stuff they're putting in their cars now :/ aren't 135i brakes like 6pot or something. eesh
'07 MCoupe
lots of mods
      02-21-2013, 01:11 PM   #39
seank
enthusiast
seank's Avatar
48
If you need brake pads for your stop techs, check out the FS thread. 30% off and only used for 1 track day. The famous PFC 01's
http://www.zpost.com/forums/showthread.php?t=805462
      04-17-2013, 03:47 PM   #40
melo
melo's Avatar
Drives: 07 M coupe
will the stoptech 4 pots with 14' rotors clear the stock wheels without spacers?
07 mcoupe ///M
      04-17-2013, 07:12 PM   #41
O-cha
O-cha's Avatar
218
Drives: Mcoupe
The stoptechs are great, can't recommend them enough. At least on my car, they are perfectly balanced and bring the whole car down when threshold braking. If you really want a set PM me.
      04-18-2013, 07:31 PM   #42
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6328
Rear yes, front might be close to fitting without a spacer. My 14" 6/4 stoptech kit fits with a 10mm spacer up front. I'm having some new tires fitted tomorrow and actually mounted the stock wheels with the spacer so I could bring my wheels in.
instagram: @ dubsesd
      04-19-2013, 04:38 PM   #43
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6328
excellent kit. fits like oem, and performs spectacular
      04-20-2013, 01:20 AM   #44
ga41
ga41's Avatar
Cyprus
31
Drives: Z4 M Coupe
Your car looks spotless! Stoptechs round the looks off brilliantly.
