09-13-2013, 07:05 AM | #45 |
Rep 2,138
Drives: Me
09-13-2013, 11:26 AM | #46 |
Certified Adrenaline Junkie
43
Rep 1,325
For those that want to change the Rod Bearing as maintenance, maybe we should compile a list of shops based on location that are recommended for replacing the rod bearings?
Beedub, Who/which company is this from? |
09-13-2013, 11:32 AM | #47 |
Rep 5,328
Lang racing
09-13-2013, 01:24 PM | #48 |
Rep 503
Drives: Z4 M Coupe
Yep, here's their blog post http://www.langracing.com/finding-a-...aring-failure/
09-13-2013, 04:41 PM | #50 |
Rep 1,663
A quick search didn't bring up the price for their rod bearing modification kit, anyone know?
09-14-2013, 12:01 AM | #51 | |
Rep 2,866
I might go in to check them out one day. Here's their blog post for addressing the problem => http://www.langracing.com/addressing...ification-kit/ Last edited by XMetal; 09-14-2013 at 12:10 AM.. |
09-14-2013, 08:11 AM | #52 |
Rep 11,667
Wow... Fantastic info here.
Nice work guys!
09-14-2013, 08:41 AM | #53 |
Rep 234
Seems like a reasonable extra expense if replacing bearings anyway. Assuming this is really a permanent fix.
I assume the new parts aren't going to provide additional power. But, I wonder if the lighter rods will translate to a faster spinup of the engine. Perhaps this wouldn't be noticeable due to the drivetrain and other variables? |
09-14-2013, 10:24 AM | #54 | |
enthusiast
48
Rep 1,695
If you can get it sufficiently oiled, you can run thinner oil which will make more power. Minimal though. I run 10-30 on my s14 where most are running 10-40/50. I have done these same mods |
09-14-2013, 05:51 PM | #55 | |
Rep 1,663
09-14-2013, 08:50 PM | #56 |
Rep 11,667
I'd love to figure out if boosting pressure is possible on the S54 as you mentioned before on the S14.
09-14-2013, 09:53 PM | #57 | |
enthusiast
48
Rep 1,695
And it's cheaper than the nla euro oil pump for the s14. And one of these while you are in there: http://store.vacmotorsports.com/vac-...kit-p1847.aspx All the issues with the s54 are exactly the same that people have with the s14. All the engine upgrades that I have seen or heard are nearly the same. |
09-14-2013, 10:57 PM | #58 |
636
Rep 3,124
I think that's already included.
Does anyone have a flow diagram of the lubrication system? I'm wondering where the CPV sits. I remember when mine started leaking I found something on the web that said something like "The Constant Pressure Valve reduces the oil pressure to the ...", and I'm kinda fuzzy on the rest. Might have been the rear main.
09-15-2013, 07:01 AM | #59 |
Rep 11,667
@Seank
I was thinking more along the lines of modifying the pressure valve to allow higher pressure. I think you mentioned something about shimming the spring on the S14.
09-15-2013, 07:51 PM | #60 |
Rep 11,667
Confirmed, I get the same numbers on my gauge.
09-16-2013, 08:16 AM | #61 |
Bad Lieutenant
232
Rep 3,517
S65 rod bearing material changed by BMW
For anyone following the E9xM3 tech area; it seems BMW changed the actual bearing material for later rod bearings. It seems the Babbitt layer has been removed. Maybe someone knows from looking at these photos taken by another board member. The only reason I can see is environmental as the new top layer looks like tin?
http://www.m3post.com/forums/showpos...4&postcount=19
09-17-2013, 07:06 PM | #62 | |
enthusiast
48
Rep 1,695
These would also be good questions for Andrew Lang. If I need to replace my bearings and/or pump, this is the route that I am going. |
09-18-2013, 06:57 AM | #63 | |
Rep 409
Another data point for S65 engines with regards to oil pressure... the Stack gauge in my M3 reads about 83 psi at steady highway RPMs. It can peak higher than that and even at idle it runs around 45 pounds. Altogether much higher than my S54 engines. When I installed the gauge, I thought I had done something wrong I was so surprised. I tried other gauges and other senders, all the same result.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
09-18-2013, 08:39 AM | #64 |
Rep 1,772
Drives: 2007 Z4M Coupe
For anyone interested in NJ area, Rogue Engineering quoted me as below:
The kit is $400 from Randy Forbes, when available. The job is approximately 8 hours...at our standard labor rate of $115/hr. I will be writing this reply in a few other threads about Rod bearings as Rogue is a pretty reputable shop which specializes in E46 M3.
09-18-2013, 08:57 AM | #65 | |
Bad Lieutenant
232
Rep 3,517
09-18-2013, 01:59 PM | #66 |
Rep 753
I am very wary of aftermarket 'improved' moving parts like oil pumps and unless I can find a few 'real' users who DD their cars and track regularly, I tend to not be the guinea pig. I would rather try and find an OE oil pump that will work on the S54 and raise oil pressure if that is helpful than have a rebuilt and 'improved' pump.
But this is a great discussion to narrow down the problem. My strategy is to replace rod bearings again and possibly rebuild the bottom end with Pauter or Carillo rods and new OEM pistons and rings on OE crank and bearings. |
