      11-16-2016, 08:48 PM   #23
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Build date: 17 Nov 2006
Purchase date: Dec 2007
Purchased pre-owned: Mar 2010 @ 12K miles
Today: 60K miles
Replacement: battery, OEM headlight, front turn signal bulbs, rear side marker bulbs, wheel-hop damage required replacement of broken engine mount, power steering hoses; replaced all drive belts, cracked windshield.
Racerbruce
      11-17-2016, 05:52 PM   #24
StickMon
StickMon's Avatar
Drives: 2006 MR
148,800 miles.
Do I win?
DEG67.50
      11-17-2016, 08:48 PM   #25
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
23k and change
      11-17-2016, 09:15 PM   #26
Mike_Z4M
Drives: Z4MC
Originally Posted by StickMon View Post
148,800 miles.
Do I win?
I think it's between you and Vanne's secret number haha
      11-18-2016, 03:20 AM   #27
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Lol Stick, you win mate, I just clicked over 135k just had to pull the tape off to have a look.
Powered by
      11-18-2016, 08:35 AM   #28
z4chick
z4chick's Avatar
Drives: 2006 BMW Z4 3.0si
I bought it a few months ago with 144k and today its at 145k. It's an 06.
      11-18-2016, 04:42 PM   #29
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
Just under 32k for me. Due for some new rubber and a valve adjustment.
      11-18-2016, 11:32 PM   #30
w3fl3x
...yummy...
w3fl3x's Avatar
Drives: M3, Z4MC
06 MC with build date of 9/13/06. Currently sitting at 56k miles. Used as my daily for a while but been enjoying the garage life the last few months.
Bunch of guys on m3forums are well over the 200k miles mark. They track their car too so shouldn't have to worry about longevity. Just keep up with the basic maintenance like oil and valve adjustments and you'll be fine. Oh and consider doing rod bearings around the 100k miles mark. Bullet proofing the vanos would be a good idea too.
      11-19-2016, 08:13 AM   #31
johno8888
Drives: 2006 Z4M
19k. New battery. Bought an 06 2 yrs ago w 5k. Summer only.
      11-20-2016, 11:08 AM   #32
pal
pal's Avatar
433
Drives: Z4 M Coupe
91K. The last three years have been minimal as the car only got driven a week or two per year.
      11-20-2016, 12:06 PM   #33
gamecoc430
Drives: 2004 Z4 2.5
2004 Z4 2.5 with 189,300 miles. Got it used last year with 184,000 on it then. I was told the engine had been replaced with a used one, not sure exactly how many miles were on the replacement engine. Car runs great, fun to drive, top only goes down and up once a year! Down in the early spring, up in the early winter. Love it!
Bob
      11-20-2016, 03:01 PM   #34
wonton180
wonton180's Avatar
Drives: 07 Z4MC
83K now. I don't DD my car, so it only gets around 4-5K/year usage. It's been very reliable even with some track days. Really minor stuff has gone like the inner halo bulb. Otherwise, normal maintenance has kept my baby on the road with lots of smiles!
      11-25-2016, 01:17 PM   #35
Patrick Gent
Drives: 2007 M Coupe
114,000 on my 2007 M Coupe. Daily driver since I bought it at 30,000 in 2010. While under CPO it had the Vanos replaced and the alternator. Other than that, just maintenance. I did learn about Blackstone testing well after I bought the car, lead was very high at first (indicator of too much wear on connecting rod bearings), by letting it partially warm up almost every time before I drive off I have that down to very good readings. Change oil every 5,000 miles. I plan to drive this car forever.
      12-02-2016, 12:14 PM   #36
jmillet
jmillet's Avatar
64
June 2007 build and August 2007 purchase/delivery. 55,000 miles on odo with many HPDS miles. Still on original battery, new street tires (Bridgestone RE760), fresh front rotors, fresh street brake pads (Akebono Euro), DIY Inspection I and II, oil change with Red Line, Greedy or Castrol TWS Edge 10W-60 every 4,000 miles, Blackstone oil analysis showing high lead (23ppm).
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      12-11-2016, 08:05 AM   #37
Sterling Roadster
Drives: e85 Z4 3.0i & e92 328i
142,000 Miles / 230,000 KMS
Love it!
      12-22-2016, 10:20 PM   #38
GyroF-16
GyroF-16's Avatar
15
Drives: Z4 M Coupe
2007 Z4MC
Build date Jan 2007
Put in service in July 2007
I purchased from Enthusiast Auto in March 2013 with 19,500 mi
Currently 48,800 mi
Spent some time as my DD with a 140 mi round-trip daily commute.
Now a non-winter driver averaging 5,000 annually, with the occasional HPDS.
Repairs:
24k - Leaking headlight sprayer and Bank 2 pre-cat O2 sensor replaced at under CPO warranty.
40k - Battery replaced
Replaced all fluids just prior to 30k, and had valves "adjusted" for the second time in my ownership at 28.5k. I say "adjusted" because no actual adjustment or shimming was required either time.
So... question for the forum: what interval for valve adjustment makes sense?
My plan is to do 30k intervals. Any downside to this?
      12-29-2016, 02:38 PM   #39
StickMon
StickMon's Avatar
Drives: 2006 MR
If you go by the "inspection" count down in the odometer, it'll say every 30,000.
My oil/inspection counter counts down 3 miles for every 2 actually driven, so if I went by it, it would be every 20,000.
I think every 30,000 is reasonable. I keep a detailed spreadsheet so I can track if they're changing.
They haven't in the last 60,000 miles. Currently at just over 150,000.
      12-29-2016, 03:42 PM   #40
NickyC
NickyC's Avatar
17485
Bought my 06 Z4M with 55k miles on it exactly 29 months ago. Car now has 73k miles on it, with zero issues ever. I've replaced a ton of cosmetic things, badges, steering wheel, shift knob, floor mats, windshield trim, 3rd brake light, etc. Also done the maintenance including inspection/valve adjustment.
It's nice to see Z4Ms in here with 115k+ miles on them, and I'm hoping these cars have never had the rod bearings replaced? I'm from the old if ain't broke don't fix it camp, and after talking with my local indie shop we've decided to leave the bearings alone (three oil reports in a row looked fantastic). A VANOS overhaul might be due this spring as preventative maintenance, but other than that I hope she just goes and goes forever.
      12-29-2016, 03:46 PM   #41
RABAUKE
Drives: Porsche 993, 2014 MB GLK
60,000 KM
      01-03-2017, 09:49 PM   #42
Molez93
Molez93's Avatar
Drives: 2006 Z4M, 2001 740i
31000 miles on my '06 Z4M
Owned since new Nov. of 2006
Other than regular fluid changes and a set of tires,
just the valve adjustment ~24k and one replacement battery.
Kinda crazy to think not a single part has "broken" in ten years
of Summer driving.
      01-04-2017, 08:04 PM   #43
Michael9218
Michael9218's Avatar
595
Drives: 2007 Z4 M Coupe
16,500 miles. 2007 Z4MC Alpine white, Imola red, with Madeira walnut dash.
Weekend car. Bought it in 2012 with 3,500 miles.
      01-05-2017, 11:11 AM   #44
Donovan303
Drives: 2003 2.5 Z4
2003 2.5 Z4 260,131.
Recently at 255,000 oil consumption went up. Compression and leak down numbers are OK. Stuck rings are suspected. Tried liqui moly engine flush and changing oil to Mobile 1 10W-40 full synthetic. We'll see.
Donovan
