08-01-2012, 10:13 AM | #67 | |
Rep 269
08-08-2012, 11:10 AM | #68 | |
Turd in the Punch Bowl
19
Rep 239
08-11-2012, 07:54 AM | #70 | |
Rep 11,667
They're just 10.9 rated bolts Pick them up at your local hardware supply.
08-11-2012, 11:18 AM | #71 |
Rep 2,867
Drives: Anything
08-11-2012, 11:38 AM | #72 |
Rep 269
As per this post: http://www.bimmerfest.com/forums/sho...2&postcount=27
It appears they are M8x25 / M8x35 (2+2 for the passenger side) with a 1.25 pitch. |
08-11-2012, 11:41 AM | #73 | |
Rep 2,867
Drives: Anything
08-11-2012, 12:13 PM | #74 |
Rep 11,667
I have a bunch in the parts drawer, I'll measure them for you.
08-11-2012, 12:38 PM | #75 |
Rep 987
For the drivers side I am pretty sure I was able to reach every bolt without removing the airbox. It just took a little thought and the correct extension. I'll go back and figure out what I did and post.
08-11-2012, 03:28 PM | #76 |
19
Rep 239
Thanks guys.. I am interested to see how you went about getting to the drivers side, Jumbosock... I really think this is good preventative maintenance. I do have a mild vibration and the passenger side front top bolt does look to be backing out slightly.. I look forward to getting this done soon.. This forum rocks!
08-11-2012, 05:06 PM | #77 | |
Rep 11,667
I just measured mine to confirm. Just did the left side while I had the airbox off, ....10min job.
08-11-2012, 11:19 PM | #78 | |
Rep 1,107
Is there a DIY for the airbox removal, or is it pretty straightforward? I pulled my back the other day so not sure when I'll be getting under the car to do the passenger side but I can do the driver's side bolts from the top probably. |
08-12-2012, 06:10 AM | #79 | |
Rep 11,667
http://www.zpost.com/forums/showthre...8#post12488118
08-12-2012, 07:05 PM | #80 |
Rep 251
If you think one or more bolt(s) is loose or coming out... don't use the car or the bolt might break in half leaving the other half inside the engine....
Been there - done that = not sexy! |
