      05-20-2015, 01:45 PM   #89
Beedub
Originally Posted by schobyb View Post
Apex ARC-8 Hyper Black on Titanium Silver, Michelin Pilot Super Sport
Front: 18x9 ET42, 245/40/18
Rear: 18x9.5 ET25, 255/40/18
Stock suspension.
The rear tires have less than 1000 miles on them, when they wear, I plan to replace with 265 or 275.
The front is a very tight fit, only 5 or 6 millimeter clearance from tire to strut. I believe there is a slight rub, but only occurring at full-lock turn.
id swap the front to a 235/40/18 and the rear 265/35/18. You'll find the front fits nicely and still looks like a thick sidewall and the rear will be slightly wider but much better looking wit the drop in aspect, they ae still thick tyres however... the 245/40 upfront on this car just doesn't work from my own static tests.
      05-20-2015, 03:49 PM   #90
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by GomboRombo View Post
Very nice. Is that on stock suspension or is there a drop?
lol See post #87
      05-20-2015, 11:43 PM   #91
GomboRombo
Roadie B4 Roady
GomboRombo's Avatar
Drives: Z4 M Roadster
lol See post #87
Glad I could amuse. I guess I should have read further....
Remus, ZHP, Stubby, H&R Coilovers
      05-21-2015, 10:03 AM   #92
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Apex PS-7
Race Silver
235/40-18
265/35-18
Michelin pilot super sport
      05-21-2015, 10:04 AM   #93
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
Pic two.
      03-07-2016, 01:16 PM   #94
DaveJB
DaveJB's Avatar
47
Drives: 2007 Z4 M Coupe
Oh man... I am signed up as interested in the ARC-8 group buy this month. I'd love to run the wheels with face profile 3 on the front. I think they're the 9.5" wide ones. They say I'd need to run more negative camber for even 255's. How are you pulling this off? Are you running more camber than factory?
Originally Posted by djdcyphr View Post
I just swapped wheels from the M3 to the Z4. Rides fine, no rubbing at all with stock suspension.
Apex ARC-8 18x9.5 et35 Square
Hankook R-S3 265/35/18 Square
Apex 5mm Front Spacer
Apex 12mm Rear Spacer
Apex 75mm M12 Wheel Studs
I plan to stack a couple sets identical to this so I can run them on both vehicles at the track or autocross. If I can scrounge the $$$, I'll do the widest staggered EC-7 setup that I can fit as my street setup on the Z4.
      03-20-2016, 11:12 AM   #95
Sliktop
Drives: 07 Z4 M Coupe
No extra camber, my Z4MC is completely stock. The 265/35/18 R-S3 fits fine...
      08-09-2017, 01:11 PM   #96
Expert@ApexWheels
Expert@ApexWheels's Avatar
3532
Drives: M3
This Z4M track machine made our knees weak
Wheels: APEX SM-10 18x10" ET25
Tires: Pirelli slicks 265/35-18
Suspension: JRZ rs pro coilovers
Alignment: -4.0 and -2.8 rear
Zero toe front and 1/8 toe in rear
Driver Notes: No spacers and no rubbing whatsoever
- Ryan
Vanne1620.50
AriuSen776.50
crfine88442.00
GPower61.00
      08-09-2017, 02:21 PM   #97
DaveJB
DaveJB's Avatar
47
I didn't share my pics in this thread yet?
I think I posted my newer pics elsewhere on this forum...
I couldn't be happier with the wheels and look of the car. The bottom pic is of the car driving off into the sunset, off with its new owner. Looks so damned good though!
      08-14-2017, 02:08 PM   #98
Z4dugh
Drives: 2008 E86 Z4 MC
Arc 8 18"
2008 MCoupe
      12-14-2018, 12:04 PM   #99
ApexWheels
ApexWheels's Avatar
1431
Drives: M3
We stopped by EDGE Motorworks MV to test fit our new 19" SM-10 wheels on our friend Jan's beautiful Z4M track car.
Front:
19x9" ET30 SM-10 Wheels in anthracite
245/35k-19 Michelin Pilot Sport 4S
Rear:
19x10" ET25 SM-10 Wheels in anthracite
275/30-19 Michelin Pilot Sport 4S
KW Clubsports w/ integrated camber plates (removed helper springs in front for inner clearance)
-3.8 camber up front
-2.2 camber in rear
Fenders have an aggressive roll
2007 Porsche Cayman S Brembo Brakes
XMetal1137.50
      12-15-2018, 09:34 AM   #100
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Front:
Rear:
-2.2 camber in rear
Looks great
But why bother with such an aggressive fender rolls in the front if all you're doing is fit 245s in there? I use the same tire combo (245F/275R) and no rub on all corners with stock fenders
      12-23-2018, 09:26 AM   #101
ljenster
Drives: Z4 coupe 3.0SI trackcar
Apex ARC-8
18x9.5 et35 245/35/18 front +10mm spacer
18x9.5 et35 245/35/18 rear
XMetal1137.50
HTM10157.00
      01-04-2019, 03:35 PM   #102
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Originally Posted by XMetal View Post
Looks great
I get you.
I'm the owner and I don't actually have this setup on my car.
I run 18x10 ET25 ARC8s w/ 275 35 Nitto NT01s all around.
Front camber: - 3.7
Rear camber: - 2.2
Tiny bit of rubbing.
      01-04-2019, 03:49 PM   #103
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by jbass524 View Post
I get you.
Front camber: - 3.7
Rear camber: - 2.2
This make more sense
The setup must stick like glue
      01-04-2019, 04:11 PM   #104
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
I get you.
Front camber: - 3.7
Rear camber: - 2.2
Thanks for the info here! Are you using any spacers? Also, where exactly is there a "tiny bit of rubbing"? Any fender rolling?
      01-04-2019, 04:14 PM   #105
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
It doesn't suck
      01-04-2019, 04:20 PM   #106
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
I get you.
Front camber: - 3.7
Rear camber: - 2.2
Lots of rolling and flattening. Cut away bits of lined too. No spacers.
I forget where the rubs were exactly but would suggest 265s instead. The picture of my car with silver ARC8s has 265s. They're an easy fit.
Azeka1285.50
      01-04-2019, 04:28 PM   #107
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thanks again - Sounds like the wheel is fine and it's more of the tire that is the concern. I currently run 265 square setup on 18X9.5 et35 ARC8 but would like to run slicks on 18X10 et25 SM-10 wheels that a friend is offering me. Looks like Alex is also running this setup so I'll give it a shot.
      01-04-2019, 05:02 PM   #108
jbass524
jbass524's Avatar
99
Drives: 2011 E90 M3
Yes, very true. Now with that I do run 275s now and it makes the lookback that little but more fun.
Is it worth it? Probably not.
Good luck!
      06-30-2019, 08:42 PM   #109
3002 tii
3002 tii's Avatar
2288
Will snap more photos in few weeks, need to sort out some braking issues but picked up new EC-7's from the group buy few months ago. Perfect fitment, functional and pleasing to eye. No spacers!
18x9 et30 and 18x10 et22
Michelin Cup 2's in 245/40 and 265/35
Slightly lowered on GC school kit with -2.5 (f) and -2.0 (r)
I may try 255/275 if I later step down to a sticky street but happy with this fitment so far.
Follow for latest mods
v3.2mc94.00
HTM10157.00
WickedNy225.00
      07-13-2019, 09:27 AM   #110
3002 tii
3002 tii's Avatar
2288
Got to test it out at Lime Rock, 245/265 surprisingly rubs but that's more probably due to my soft spring rates. The only area where it rubs statically is the rear liner of the front wheel (behind headlight) on lock-to-lock. So for street, 95% it's a non-issue.
Based on this I may just stick to 245/265 for track days.
