02-02-2019, 06:53 AM | #2 |
Rep 12,565
Pretty much but even if you did it appears the bar uses a hinge design anyway so you could do better IMO
02-02-2019, 06:55 AM | #3 |
#buildnotbought
10855
Rep 4,893
If it doesn't have to be Dinan per se, you could look at strongstrut, which is still for sale I believe:
http://www.strong-strut.com/Z4/front...20strut/Z4.htm And arguably better (stiffer?, lighter?)
02-02-2019, 11:25 AM | #4 | |
Rep 154
02-04-2019, 02:08 PM | #5 |
mr G
14
Rep 13
you could try this one instead as it is very similar to whats in ur picture from cosmos racing; https://www.cosmoracing.com/
02-04-2019, 06:14 PM | #6 |
Rep 382
If you have aftermarket suspension/camber plates and your main center strut bolt/adjustment knob sticks past your strut mounting area then the only strut bars that will work are the OEM(very rare) and the Turner motorsports one(takes about two months to receive). The mounting plate on the strut bar has to have an open center design to allow for clearance.
02-11-2019, 11:58 PM | #7 | |
Rep 4
