      08-14-2016, 02:19 PM   #1
Philly_sweden
Philly_sweden's Avatar
Sweden
580
Drives: BMW M2 2017
  [10.00]
  [9.50]
2017 BMW M2   [7.83]
Z4M: Will these wheels fit? Click for pic + Spec
Will these fit my Z4 M Coupé?
Cades Shift
Front 18x8 ET35
rear 18x9 ET40
/Filip
      08-16-2016, 07:51 PM   #2
UPWheels
UPWheels's Avatar
52
Drives: E60
Those specs will fit fine. You can add spacers for a more aggressive stance if you want to make it flush with your fenders. Make sure the PCD is 5x120 with a 72.6 CB.
      08-16-2016, 10:25 PM   #3
The HACK
The HACK's Avatar
1821
On an M? You sure?
      08-17-2016, 12:01 PM   #4
UPWheels
UPWheels's Avatar
52
Drives: E60
Originally Posted by The HACK View Post
On an M? You sure?
The original Z4M wheel specs are
F 18 x 8 ET42
R 18 x 9 ET30
So with a ET40 rear, it will be 10mm more tucked in or sunken in compared to OE. It might clear your struts and calipers. If not, spacers will be required.
      08-17-2016, 01:23 PM   #5
The HACK
The HACK's Avatar
1821
I'm not so sure that the rear will fit without a spacer, although I have seen someone run one of the front 8" wide rims in the rear in a pinch and it sort of fits. Regardless "those will fit fine" wouldn't be my first recommendation.
At the MINIMUM a 10mm spacer is required to push the track out to the same spec as factory in the rear. Depending on the tire(s) used there might be some rub on the inside without it. Heck when I run 275/35/18 Toyo Proxes on 18" x 9.5" et 26 wheels on the rear, it would rub the inside fender well ever so slightly on high-G corners. And that's only 2mm less inside clearance than STOCK based on offset calculations.
I dunno. I'm not a wheels or tires expert. Those offset looks to be intended for a non-M E36/E46/E85/E86 fitment. I wouldn't run it without a 10-15mm spacer in the rear. But that's just me.
      08-17-2016, 03:46 PM   #6
UPWheels
UPWheels's Avatar
52
Drives: E60
http://www.zpost.com/forums/showthre...40#post9673104
2007 Z4M 17x8 ET40
      08-17-2016, 04:33 PM   #7
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
As you've indicated - Those are 17x8 ET40. OP is asking about 18x9 ET40, which have less clearance (13mm less) on the inside. I'm also doubting that OP will run 225 tires (as per your link) on a 9 inch wheel.
      08-17-2016, 06:42 PM   #8
UPWheels
UPWheels's Avatar
52
Drives: E60
Where's my head at today? Original Z4M rear wheels are 18x9 ET30. ET40 will have 10mm less clearance. OP, measure the inner clearance from suspension to wheel and tires, and see if the 10mm tuck will come in contact. If not, you're in the green. If it does, you need spacers. Also, I spoke to our Rep at TireRack and they have 18x9 ET40 offered for the Z4M and they guarantee no spacers required.
Of course the 225 will not accommodate the 9" wide wheels.
      10-02-2016, 07:23 AM   #9
Epwebb64
Drives: 07 Z4M Coupe
What wheels are those? Where did u find them. I like tham alot.
