      01-23-2012, 07:49 PM   #1
msh441
msh441's Avatar
17
Drives: 2007 BMW Z4 M Coupe
Best ultra low profile jack for the $???
Greetings,
I\'m looking for the best, ultra low profile floor jack for the money.
Something I can slide under the front of my (standard suspension) Z4MC and reach the center/front jack point. Get both front wheels up at once.
Any pointers/links/etc. would be appreciated.
Mike
      01-23-2012, 07:55 PM   #2
Kgolf31
Kgolf31's Avatar
459
Drives: 2007 Z4MC, 2012 128i
http://www.harborfreight.com/15-ton-...ump-68054.html
I have this one. It EASILY gets under the suspension. They have different ton ratings if you're going to be lifting the whole car, but since I have a standard 3 ton...I can use this one to Jack it up and get my other jack to the center if need be.
I got mine on sale for $70 too.
      01-23-2012, 08:06 PM   #3
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
The costco low profile! lot of members here have it
The Raspinator
      01-23-2012, 08:07 PM   #4
SCHMOUPE
SCHMOUPE's Avatar
http://www.garagejournal.com/forum/s...ad.php?t=36136
The Raspinator
      01-23-2012, 08:21 PM   #5
RADRACR
RADRACR's Avatar
I don't think any jack unless it's SUPER long will reach the front center jack point. Someone can correct me if I'm wrong.
I like the Tire Rack one because it's aluminum and I need to haul it up and down from my apartment. It is long enough to reach the rear center jack point. http://www.tirerack.com/accessories/...m=TRJACK&ID=67
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      01-23-2012, 08:46 PM   #6
mhughett
Drives: 2007 Z4 M Coupe
I agree, you can't get any jack all the way to the front-center jack point. You need to lift one side first and then get to the middle jack pad. By the way, I have two harbor freight jacks and I've had great luck with them.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      01-23-2012, 08:59 PM   #7
johanness
Drives: 2008 Z4MC
This. Torin jack, minimum height = 3" 7/16. Works well
      01-23-2012, 09:05 PM   #8
Ron Stygar
Drives: 2006 Z4 M Coupe
I have three that fit the front. Sold the AC one.
Other are Sears and the one I use all the time is a two ton Lincoln.
I have the second moded Sears aluminum one for sale.
      01-23-2012, 10:34 PM   #9
txz4
txz4's Avatar
59
Drives: 2006 M coupe
I have the same jack as the costco one, bought at northern tool. Works great but its REALLY hard to lower slowly once loaded.
question for everyone, not to derail, but what jack stands are you using? i have the Tire rack style expensive ones and they dont work with the jack pads at all.
      01-23-2012, 11:05 PM   #10
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I have a sears aluminium one I got on sale
      01-23-2012, 11:50 PM   #11
Ron Stygar
Originally Posted by msh441 View Post
Greetings,
Mike
http://www.unofficialbmw.com/frame_ron.html
You can see some jack items under (TOOLS)
Jack I use is W93642:
http://www.unofficialbmw.com/all/too...ulic_jack.html
Lowered, I use these:
http://www.unofficialbmw.com/all/too...ered_cars.html
      01-23-2012, 11:52 PM   #12
kcdedric
kcdedric's Avatar
Drives: E90 M3
Not the cheapest option, but check out posts #16 and #20:
http://www.zpost.com/forums/showthread.php?t=576427
Le Mans Blue '09 BMW M3 Sedan - Current
Polar Silver '04 Porsche GT3 - Gone
Persian Blue '08 Lotus Exige S240 - Gone
Space Gray/Imola '08 BMW M Coupe - Gone
      01-24-2012, 09:36 AM   #13
tekmoe
tekmoe's Avatar
55
Drives: ///M
Harbor Freight. Best jacks for the money. Case closed.
      01-24-2012, 11:29 AM   #14
MinneapolisJeff
Drives: 2003 BMW Z4 3.0i
I have this jack as well
the stable:
2003 BMW Z4 3.0i
2020 Mitsubishi Outlander SE
2021 Jeep Gladiator Rubicon
      01-24-2012, 03:39 PM   #15
mhughett
Kgolf31--I don't see how you can use the front/center jack pad with this jack without first putting the car on ramps or raising either the left or right front jack pads. The jack is not long enough to reach it and still have room to pump the jack. Some of the jacks noted on this thread are long enough to do this but not this one and not the one noted by Ron Stygar (W93642). Am I missing something?
      01-24-2012, 03:42 PM   #16
Kgolf31
Kgolf31's Avatar
459
As I said, maybe in my first post it didn't come out right.
I don't use this jack for central jacking. I always lift a side, and if need be I take my craftsman 3 ton and use that for central. Since this one is only rated at 1.5 tons...I don't trust it for this duty.
I got this jack because it's cheap and fast. I change my wheels each time I autocross, so something fast and easy is what I needed (and my air gun )
      01-24-2012, 06:46 PM   #17
Ron Stygar
Purchase the AC jack if you don't want the made mini ramps.
http://www.bimmerfest.com/forums/sho...0&postcount=37
Lincoln:
I drive on the mini ramps. Put on the double chocks.
Jack the car up. Drop into my modded jack stands.
Push in the metal ramps as a back up.
http://www.bimmerfest.com/forums/sho...7&postcount=60
      01-24-2012, 10:27 PM   #18
04z4
Drives: 2004 BMW Z4 3.0i
I am quite happy with my 3.5 ton Arcan XL325R. Made in China but it is very solid. And heavy. Available on ebay, Amazon, Northern Tool, etc. Search for "Arcan jack". It had many positive reviews if I recall.
      01-24-2012, 10:35 PM   #19
elerner61
elerner61's Avatar
157
Drives: '07 Z4M Roadster
I cut small pieces of plywood that fit in the jackpads to use on my Tire Rack jack stand. Works just fine.
      01-24-2012, 10:37 PM   #20
txz4
txz4's Avatar
59
the thought of balancing a piece of would on a stand and than my car after that frankly scares the shit out of me. If worse comes to worse i may route out an indention for the pad to partially fit into and then route an indention for the angles of the jack stand.
      01-24-2012, 10:39 PM   #21
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
I use larger pieces of plywood to put in between the jack and the jack points.
      01-24-2012, 11:27 PM   #22
RADRACR
RADRACR's Avatar
Your idea sounds good in theory but doesn't work out so well in practice because it's hard to target the area exactly when dropping the car. I tried this. I too, have the Tire Rack stands and use pieces of wood to set on top of them. It sounds scary, but once the weight of the car is on the wood, it's not going anywhere. It also makes it easier to place the car on the stands because you're dealing with a larger surface area. If I had the tools, I would certainly route a hole as you mention to sit the wood securely on the stand, at least.
