04-07-2014, 09:45 PM | #1 |
Rep 413
Drives: Z4 3.0, CLS63 AMG
My NAV DVD won't eject!!
I have an '05 Z4 with NAV and recently updated the maps. I'm not sure if the update had anything to do with this, but now I only get "please wait a moment" displayed on the screen and I'm unable to eject the NAV DVD. "Please wait a moment" displays regardless of trip duration. Every time I switch over to navigation the only thing I see is "please wait a moment."
I've tried disconnecting the battery for 15 mins to reset the system and hold the eject button once connected, but still no luck. I've even tried having my wife hold the eject button while I re-connect the battery. Any ideas??
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG Last edited by wasupdu; 04-07-2014 at 09:54 PM.. |
04-08-2014, 06:51 AM | #2 |
#buildnotbought
10866
Rep 4,895
I've had this problem too (when I bought the car and wanted to swap dvd's), and I think it has to do with the mechanism, and that something is physically jammed, or an internal switch/sensor in the mechanism is not pressed correctly (so no electrical issue; I also tried all the things you did).
What I did is take a small knive (pocketknive), and put a small piece of strong double sided tape on the end (about 1x1cm), and stuck the knive in the slot so that I could press the tape bit on the top side of the dvd, and pulled it out with a little force while pressing the eject button. After that the mechanism worked fine; dvd's go in and out with no hassle.
04-08-2014, 09:36 AM | #3 |
Proud E86M Owner
79
Rep 650
taking it to a dealer? Possible a save way to get it solve.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute) 2016 Honda CR-Z EX Jet Black (Daily Commute) 2008 Kawasaki ZX6R Plasma Blue (SOLD) 2008 Z4///M Roadster Space Gray (SOLD) |
04-08-2014, 10:21 AM | #4 |
#buildnotbought
10866
Rep 4,895
.....And getting billed for a new mk4 incl installation
04-11-2014, 10:45 AM | #6 | |
Rep 413
Thanks for the tip! I tried this and was able to pull the DVD out, but now I can't get the DVD back in. The NAV screen still displays my coordinates and elevation, so the computer is still good. I'm hoping that I can just replace the mechanism inside the DVD drive rather than replacing the entire unit. It looks like the mechanism can be found for about $130 and looks to be fairly easy to replace. We'll see... |
04-12-2014, 10:03 AM | #7 |
1621
Rep 4,294
No offense bud, glad you got the DVD out, but why bother? The mk4 is the biggest piece of crud this side of gps nav planet. Terrible unit, terrible to use and even more arcane to program. What a complete waste of nav in my bimmer. Oh did I forget to mention that you can't even enter a lat/long co-ordinate? What a shame. Glad you got it out though ; )
04-12-2014, 11:43 AM | #8 |
#buildnotbought
10866
Rep 4,895
^I have no problem typing in an address and arriving at the destination...
Maybe not the flashiest looking nav, but hey, it was designed in the early 2000's (just as the z4 was). I think it's even more user friendly than some modern systems. (I've used some pretty bad modern (post2012) ford&volvo systems) Why would you want to type in lat/long coordinates? You're planning to turn it into a boat?
04-12-2014, 05:59 PM | #10 | |
Rep 1,034
You may hate it, but I think it's perfectly adequate. I use my phone to look up the destination and use the MKIV nav for directions.
05-01-2014, 09:19 PM | #11 |
Rep 413
Would a new DVD drive mechanism work at this point, or do you think I'm SOL and have to replace the whole unit?
Here's one for $100 on ebay http://www.ebay.com/itm/181275331634...84.m1423.l2649
2013 Mercedes CLS63 AMG |
05-01-2014, 09:38 PM | #12 |
#buildnotbought
10866
Rep 4,895
That's a repair shop and not a module. They may replace the 'mechanism', but that is usually the laser pickup. (you can buy those on ebay too, those are usually the things going wrong (worn out laser, and yes, they're cheap:http://www.ebay.com/itm/Optical-lase...98980d&vxp=mtr)).
Your problem may lie in the eject mechanism itself (that is another part than the laser pickup). Although faulty reading may interfere with eject. Anyhow that being a repair service you may contact them. They have experience with these units and may have a spare eject assembly lying around. I might replace the laser myself in the near future as I experience more and more read errors. But that might also be my crappy modded DL'ed 2013 dvd from a questionable source
05-02-2014, 03:45 AM | #13 |
1621
Rep 4,294
surely its just a shitty dvd rom reader, stock bog from a pc? sure looks like it.. i bet it even has the atapi interface at the back? has anyone tried to just replace it with a similar PC unit?
ok, ill take that back, apparently its a specific unit.. bloody hell. they go for around 450-850 US.. lol .. piece of crud. i guarantee when mine fails i will not be replacing it, ill be ripping the darn thing out. (and its bloody noisy too if it has a disc in there)
Powered by |
05-02-2014, 04:08 AM | #14 |
#buildnotbought
10866
Rep 4,895
If you hate it that bad, why don't you rip it out immediately now it's still good.
Put it on ebay and cash some money. Win-win situation. you're welcome
05-02-2014, 11:18 AM | #15 |
1621
Rep 4,294
I would do that in a heartbeat, but id recon the resale vale might affect the car with no nav. thanks for the tip though G, by the way, where a bouts in NL are you from? we have a holiday house in the south near eindhoven… lovely place that little country.
Powered by |
