      08-23-2013, 03:26 PM   #1
08z4mroadster
Drives: Z4MR Grey
Works Meister S1 3P 18" wheels
Hi everyone, I'm thinking put one of these to my Z4M Roadster but not sure about the best offset to fit on. Any recommendation???? Thank you so much!
F: 235/40/18 18x9 - ET??
R: 275/35/18 18x10 - ET??
Photos with information would be nice. Thanks guys ~~~~
      08-23-2013, 03:50 PM   #2
dorifto88
Drives: 88 Nissan Pathfinder
18x9.5+29 235/40/18
18x11 + 17 265/35/18
      08-23-2013, 07:02 PM   #3
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
daaaaaaaaamn
      08-23-2013, 08:26 PM   #4
dorifto88
I'm a bit drunk so I apologize if I come off as a prick. do not get the sizes I mentioned above unless you are ok with rubbing during hard compression. mfanatic and snk can attest to this lol
      08-23-2013, 11:19 PM   #5
seank
enthusiast
seank's Avatar
48
Since he's drunk, I will put it simpler. It's very AGRESSIVE!
      08-24-2013, 03:31 PM   #6
Jroc
Drives: Mcoupe
18x9.5+29 235/40/18
Best shot of your car yet
07 TiAG Coupe
@Jroc561
      08-24-2013, 11:55 PM   #7
EMP07
EMP07's Avatar
37
Drives: Z4M
Gangsta!
BTW going to be at Laguna on the 15th (trackmasters) and maybe Sonoma on the 21st
BSM Z4M Coupe
      08-31-2013, 10:11 AM   #8
604skyline
Drives: 2020 M2 CS
18x9.5+29 235/40/18
you can run a 235 on a 9.5" wide wheel? how stretched are the tires then?
      08-31-2013, 08:49 PM   #9
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
I have 235/35/19 on a 10 right now and it's not that stretched. Aggressive to some but not extreme by any means.
      08-31-2013, 11:14 PM   #10
seank
enthusiast
seank's Avatar
48
Really? Let us judge.
      09-01-2013, 02:01 PM   #11
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Could care less who "judges". I've run plenty of tire setups in the past 9 years to get a good enough idea of what is what. Everything from "meaty" setups on my e46 M3 to stretched "stanced" on my bagged TT and e46 non M's.
Here's the best shot I have right now with it not aired all the way down in the rear. Commute 65+ miles a day on them with no problems and my work even has a 200 yard gravel and dirt driveway. Wear is excellent as well since I ride at an OEM height.
The tires were mounted by America's Tires which means they're well within spec. They are extremely strict when it comes to mounting anything outside of spec due to company policy, meaning they won't even entertain the idea.
      09-08-2013, 02:53 PM   #12
08z4mroadster
Drives: Z4MR Grey
Nice rear set up ... That's what I want ... any more photo? And wht is the full spec on this set? Hank you all help
      10-16-2013, 08:32 PM   #13
pocket hercules
Drives: Z4M
19x9.5 et17 front w/ 235/35, 19x11 et17 rear w/ 275/30.
Make sure you get the right disk size
I think I have a A disk up front and O disk in the back.
I see other guys running et23 O disk for more Lip up front.
