      03-22-2011, 10:04 AM   #23
3002 tii
3002 tii's Avatar
2282
Originally Posted by v3.0si View Post
are you running 255/35's on the rear now? is it feasible you could swap one to the front just to test the car's static clearance? that way, if it works parked, the confidence to try a rolling test squared will be bolstered...
currently running 225's on all 4. these were the tires i had previously when i was running 8" on all 4 but they will need replacing soon, and thus wanted to take advantage of wider tires.
looking at wassup61's setup of 255/40r17 on 8.0" et41...
a 255/35r18 (which is damn near identical to a 255/40r17) on an 8.5" et42 will be 5mm MORE aggressive on the fender side. if he had clearance issues at the liner, you will absolutely have clearance issues in the same spot.
yea i believe it... i was led down to this path when i read many e46 non-m owners saying yes it could be done, and yes they've done it. for some reason i thought our clearance, offsets, etc were similar. thanks everyone.
Follow for latest mods
      06-23-2011, 10:42 PM   #24
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
what sizes did you end up with? i have a chance at some beefy tread, and interestingly enough, your results may well decide what's going on my car next. (me and my maths are up to no good again)
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
