10-31-2010, 02:14 PM | #23 | |
Rep 4,726
They are awesome for getting the wheels on and off easily and then not having to worry about cross threading the lugs. I've found the short ones can work with a 15mm spacers too, but that is somewhat dependent on the wheel.
12-24-2010, 02:42 PM | #24 |
Rep 91
Drives: 2007 Z4MC
wheel stud conversion
What length of wheel stud should I use with OE wheels ?
Will most likely buy from TMS Thanks Wayne |
12-25-2010, 08:31 PM | #25 |
Rep 1,143
12-27-2010, 09:02 AM | #26 |
Rep 12,565
But if you know you're not going aftermarket, then you can go shorter which will be cheaper and wont require extended lugs (not that these are necessary but might look weird with studs sticking out so far)
01-02-2011, 07:47 AM | #28 |
Rep 12,565
01-02-2011, 01:49 PM | #29 |
Rep 725
^they're fine. same as post #22
However I run a 12mm spacer up front. I was doing that in the rear too but the Yokohamas AD008 in stock size are too wide. The studs aren't as noticeable in the rear anyhow because of the wider wheel. |
05-07-2012, 10:25 AM | #30 |
instagram 997turbotom
279
Rep 7,377
Anyone know where I can get a bronze colored 90mm stud kit? I'm assuming thats the size I need for my 20mm spacers
05-07-2012, 11:33 AM | #31 |
Rep 12,565
No such thing (or not that I know of). You'd probably be better off looking for extended lugs in bronze, since that's what you'll see anyway after everything is mounted.
05-07-2012, 11:43 AM | #32 |
279
Rep 7,377
I found these, but I'm doubting that they're good quality
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
05-09-2012, 12:58 AM | #33 |
279
Rep 7,377
anyone heard of this brand? http://www.jhpusa.com/store/pc/viewC...idCategory=680
05-09-2012, 09:42 AM | #35 |
279
Rep 7,377
75mm turner studs are long enough for 20mm spacers, right?
I ordered a set of those gold chromoly lugs. Should look good on the matte black TE37s on sepang The 75mm studs are on a 1-2 week backorder right now
05-21-2012, 04:48 PM | #36 |
John 14:6
59
Rep 587
I purchased a stud/lug set at Bimmerfest from Motorsport Hardware.
75 mm Bullet Nose Studs & Neochrome Lugs http://www.motorsporthardware.com/cm/Products http://www.facebook.com/MotorsportHardware
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... Last edited by misterawa; 05-21-2012 at 04:56 PM.. |
05-21-2012, 08:28 PM | #37 |
Rep 11,667
IIRC, Max for 75mm stud is a 12mm spacer.
05-21-2012, 09:00 PM | #38 |
///M-fanatic
193
Rep 3,885
haha I like the neochrome look, but unfortunately they're crazy played out by the ricer community
Such a shame, cause they're pretty to look at, and the ricer representation doesn't do them justice at all |
