      09-16-2015, 01:04 PM   #23
StickMon
StickMon's Avatar
Drives: 2006 MR
Exhaust camshaft position sensor (19).
      09-16-2015, 01:23 PM   #24
BGR
Drives: C7 GS 7MT; e90 M3 6MT
Yeah thanks. Just found it on REALOEM. Not sure if that could be causing this.
It's not like it runs rough under throttle, it's that once the RPMs hit about 1,500 the whole system cuts out then catches itself around 800rpm.
Going to the shop tonight.
      09-16-2015, 03:31 PM   #25
BGR
Off to the doctor.
      09-16-2015, 03:36 PM   #26
Westersund
Westersund's Avatar
Sweden
496
Drives: BMW
Originally Posted by BGR View Post
Did you get any error codes indicating that was bad anywhere along the way?
I didn't bother reading the codes, I went by experience.
A faulty camshaft position sensor can act almost like a faulty crankshaft position sensor. If you had oil in the connector you circled in on the picture of the S54 it can give bad readings to the ECU thus causing this problem. Try cleaning it with some electric cleaner.
      09-16-2015, 07:48 PM   #27
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
It's the exhaust camshaft position sensor. The oil that got in that sensor probably came from a worn out o-ring. Part #17 in that Realoem link.
/// Vibra-Technics motor mounts /// Autosolutions SSK /// RE Tranny mounts /// Aero Turbine Exhaust /// Beisan Vanos upgrades /// SDW rtabs /// Fortune Auto 500
      09-17-2015, 04:23 PM   #28
BGR
Well, my speed shop spent six hours today trying to diagnose the issue and couldn't figure it out. Following the BMW troubleshooting guide, it takes them to the throttle position actuator (I believe that is what they said). Before tackling the 5.5 hour replacement job, they want to rule out other possibilities. I encouraged them again to check the camshaft position sensors as I did when I dropped the car off yesterday, so that is what they will try and test tomorrow morning.
      04-25-2016, 10:10 AM   #29
BGR
Quick update. Pulled the car out of storage and hesitation seems a little worse than before. Before tucking it away, these were all of the codes it would throw.
// BMW Trouble Code list
// ECU Type : Siemens DME MSS70
// Vehicle Manufacturer Ecu Hardware Number : 7839868
// Vehicle Manufacturer Ecu Software Number : 7838888
// Hardware Reference Number : 0049R200840S0YWHE
// Vehicle Identification Number : 5UMDU93466LL93207
// Ecu Manufacturing Date : 08.02.2006
// 1) 2C9E No Fault Code description found !
// 2) 2C9F No Fault Code description found !
// 3) 2EA1 No Fault Code description found !
// 4) 2E9F No Fault Code description found !
// 5) 2DE3 No Fault Code description found !
// 6) 2DE2 No Fault Code description found !
// 7) 2DE1 No Fault Code description found !
// 8) 2C93 No Fault Code description found !
// 9) 2A15 No Fault Code description found !
// 10) 2A1B No Fault Code description found !
      04-25-2016, 12:06 PM   #30
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Most of those have descriptions and can be found by googling the code plus BMW: "2EA1 BMW".
Now the interesting thing about that 2EA1 is it shouldn't even turn up in the S54. That's for an oil condition sensor something this car doesn't have.
Two.of the codes I looked up has to do with gas tank ventilation or leaks. I guess that's either a bad gas cap, filler neck, or charcoal ventilation system. http://www.bimmerfest.com/forums/sho...d.php?t=676625. I think there's a small pump that addresses ventilation. At least there is in the E46 3 series. See here. http://www.e90post.com/forums/showpo...6&postcount=11
There are a couple of codes here for O2 sensors. http://www.bimmerfest.com/forums/sho...d.php?t=432282
I didn't search through all of them but the links I provided, along with a general search, allow you to track down most of these.
      04-25-2016, 12:42 PM   #31
BGR
The car has an S54 from an e46 m3, which I believe has the condition sensor built in to the temp or level sensor.
The fuel codes are because one of the breather vents got worn through from the last owner running lowered suspension and wide wheels. I'll be fixing that shortly.
Thanks for your help and links.
      04-25-2016, 01:48 PM   #32
Finnegan
Finnegan's Avatar
You're welcome. Tank faults make sense with the codes then given breather vent issues.
The other codes, which are O2 related, would cause the issues you're describing--IIRC the ECU defaults to a rich setting when those fail.
Chase those two areas down and hopefully that addresses your rough running issues.
Were those codes pulled with a generic reader? I'm thinking "yes" as the codes listed are, I think, BMW specific/extended codes. A cheap knock off cable from eBay attached to a laptop is quite helpful if you don't have one--although with the tune maybe you do?
      04-25-2016, 02:04 PM   #33
BGR
They were pulled using ESS's software and OBDII dongle.
