      06-02-2016, 10:12 PM   #23
RonRock
Drives: 2007 Z4
Originally Posted by tambyz4 View Post
Just to add to this thread, I had a similar problem with my 07. Couldn't figure it out, until I read a ton, then started playing around with the rear shelf. It wasn't the shelf or the sensor, turned out the red ring that pulls to release the hydraulics was partially pulled out. I put it completely in and everything started working.
Just incase another person has the same issue. Something to check.
JT
Thank you for taking the time for the post. I just "fixed" my wife's Z4 top issue, thanks to your post.
Took a lot of searching to find such a simple solution. But it worked and I am thankful.
Cheers,
Ron
      07-18-2016, 10:03 PM   #24
Forbes
Daily driver/Weekend mechanic
Forbes's Avatar
Drives: '06 Z4 3.0i Roadster
2006 Z4 3.0i  [6.00]
2014 BMW 328i  [0.00]
So this problem kept recurring and I had to keep re-fixing the shelf - the last time, it was a bit harder to fix, getting worse. Thought what a crap engineering design. Is this how my roadster will end? one day I was cruising the diagrams on RealOEM and saw the clips, once priced at less than a dollar each. My crap mechanic didn't replace the clips when he replaced the back shocks.
So I had to fork out not 1 dollar for each of the 4 clips, but 10 dollars for each of the four clips from getbmwparts.
Anyone know how to install them? I haven't looked yet.
      07-19-2016, 06:13 PM   #25
StickMon
StickMon's Avatar
Drives: 2006 MR
IIRC, they drop in from the top side while the tray is raised about 1/2 way up.
And they're asymmetrical, so they have to be right way round.
      08-21-2016, 04:44 PM   #26
bigjet
Drives: 06 BMW Z4
just ordered a new cable
      04-15-2018, 04:56 PM   #27
Ice-Man
Drives: 2003 BMW Z4 2.5cc
I think I could use your help man. Any way to reach you via email? I have this same issue on my 03 'z4 and i would love to know how to fix it properly. Any help will be much appreciated..
      04-15-2018, 04:59 PM   #28
Ice-Man
I need your help buddy..
Is there any way to reach you via email?
I have this same issue on my 03' Z4, and I have some simple questions but I don't know who can help me on this until I joined this forum and I saw your post. Any help will be much appreciated. Thanks in advance!
      04-15-2018, 06:59 PM   #29
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
Not going to get much help from someone who posted 2 years ago, but post up a new thread with your specific issue and we'll see if we can help. Need the specifics of when the issue started, exactly what the symptoms are, etc.
Top Down 365
      04-16-2018, 01:51 AM   #30
MontereyZ
Drives: None-yet
2006 Z4 3.0i  [7.00]
I finally found a mechanic who would repair mine (2006 3.0i). The dealer wanted about $2400. The dealer 'examined' it and said that the entire top would have to be removed to inspect further. I eventually found a BMW mechanic who did it at my house and I replaced the pump. It wasn't corroded but I didn't want to reinstall the top and find it was bad. It's a pain in the a** job as you have to squeeze into the trunk to get it out. I don't think it is a favorite job for a mechanic. I would up paying about half of the dealer cost. The job was way beyond my skill set so I didn't want to take a chance on making it worse. Shipkiller's video is the best around.
      03-11-2020, 04:26 PM   #31
mas3423
Drives: BMW Z4
I am in the processing of sourcing a Mustang motors/pumps. This might be a dumb question, do they come with fluid already in the tank, or do we have to add it? The one I found, is missing the hydraulic line bolts and the tank looks empty. They are asking $125 for this.
19" Beyern Mesh Wheels / Dinan Exhaust / Dinan Stage 2 Software / AFE Intake / Umnitza LED License Plate Bulbs / Apexcone 3000k HID Fogs / Yellow Laminex / ZHP Short Shift Knob / Color Matched Stubby Antenna / 35% Tint / Valentine One Radar Detector
      03-31-2020, 11:15 AM   #32
SRQ
Drives: bmw z4
roadster top won't go down
Thanks Guys, have lot's to try now.
SRQ
      04-10-2022, 03:19 PM   #33
Falbe_C
Drives: 2007 BMW E90
interesting
      03-26-2023, 07:01 AM   #34
Ronnie Cavanagh
Drives: BMW Z4 2003
Bmw z4 2003
I have looked at the shelf ,micro switch for soft top.Windows go down red light flashes and motor makes noise but nothing happens.Trying to close red light flashes and it will latch manually but windows don’t go up should they ?
Don’t want to go into pump until try all else.Is there a relay switch or fuse that may be blown also ?
      07-19-2023, 01:26 PM   #35
Donkman
Drives: 2005 BMW Z4
Red tab in the trunk
My top won't go down or up . I can hear the hydraulic motor running but thats all. I pulled the red tab in the trunk to release the hydraulic fluid and it goes down manually fine. When trying to get the red tab back in, it won't go back. Does anyone know how to fix this?
      07-20-2023, 10:02 AM   #36
Clearancediver
Drives: 2004 Z4
It’s a quarter turn valve release… so you need to pull and rotate it opposite way that you used to release…. To engage it
Sent from my smart phone...
      07-20-2023, 10:06 AM   #37
Clearancediver
Drives: 2004 Z4
Read these…
https://www.google.ca/search?q=z4+to...&client=safari
