      06-28-2016, 08:48 AM   #1
Diesel_d66
Drives: '07 MR
Top motor may be dead
I was enjoying a nice top down day on my drive to lunch and decided the car needed a wash. Took it to a hand wash place, got it back nice and shiny, lowered the top and drove back to work. After work, lowered the top, drove home, and when I got home the top died halfway up. Had to manually raise it.
I'm guessing my top motor is dead even though I had removed the driver side drain plug. Any suggestions on how to trouble shoot? Am I looking at $2k for the labor and parts to replace the motor? If so, does anyone want to help me out on a weekend to replace it with me? I'm willing to pay for your time. I appreciate any advice.
      06-28-2016, 09:02 AM   #2
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
I paid 1k(parts + labor) for motor at an indie.If it's just the motor(probably),that's about what it should run you.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      06-29-2016, 08:28 PM   #3
dc_wright
dc_wright's Avatar
249
Drives: 2006 Z43.0si Roadster
If you're reasonably mechanically capable you can replace the motor yourself. Shipkiller's DIY guide is pretty straight forward. http://www.bimmerfest.com/forums/sho...&postcount=114
Top Down 365
      07-01-2016, 07:17 AM   #4
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
I paid about $800 total getting a used motor off the classified section at my indie shop. $2k seems like a lot even for stealership.
      07-01-2016, 08:48 AM   #5
deemo319
deemo319's Avatar
Drives: BMW
I got a brand new motor and clean out vacuum lines before I took delivery of mine last June.
There was a tropical depression a few weeks ago and it rained for a while here on Florida.
Went to put the top down after the storm and the top motor sounded muffled which meant it was UNDER WATER!
Spend about four hours yesterday on due diligence about getting a new top motor moving the top motor to the trunk, I got a quote for $1,500 plus the move. Sounds way too high so more research is needed.
Good luck to you.
      07-02-2016, 03:49 PM   #6
dc_wright
dc_wright's Avatar
249
Dealership typically quotes $1,800 - $2,000 for the top motor replacement. The motor/pump assembly is about $600 dealer price plus about 8 hours labor at dealer rate. It adds up pretty quickly.
Good luck to you.
I moved my motor to the trunk last time I had the top off. The move itself isn't that much work, but if you remove the top to do it you're looking at a lot of labor. I already had my top removed to replace the lift cylinders and the top canvas.
Looks like you're here in Orlando? If so and you want a hand drop me a line.
File Type: pdf Z4 E85 Top Motor Relocation (Revision 1).pdf (2.76 MB, 181 views)
Top Down 365
      07-02-2016, 08:40 PM   #7
deemo319
deemo319's Avatar
Drives: BMW
Good luck to you.
dc,
I want to move the motor to the trunk because I think if I don't I just may need to do this again next year.
Thinking of just having the top manual, but I probably won't do that.
Currently I am waiting on a call from a shop in Winter Springs since they did two Z4 tops this week.
Let's talk so you can walk me through the process, if you don't mind. I will buy drinks!
And yes, I am in Orlando.
      07-07-2016, 07:17 AM   #8
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
+1 for DIY with Shipkiller's guide. It's not so bad, and don't need any special tools IIRC. I had to replace the pump on my old 3.0i sport a few years ago, I believe I paid around $400 for a new pump and maybe some fluid, can't remember... But I do remember thinking after I was done that I could do it again within an hour or two.
Watch the paint if you decide to!
she’s home! '22 M4 Comp xDrive
      07-11-2016, 09:59 AM   #9
Diesel_d66
Drives: '07 MR
is there anyone in the maryland area that's willing to fix the pump with me? I'm willing to buy the parts and pay for the help.
      07-17-2016, 09:27 AM   #10
m3griff
Drives: Z4 3.0Si
I had mine die in a similar fashion last fall. I replaced the motor only to find out is was actually a broken wire in the harness that rubs along the tops passenger side. This harness connects the various sensors and limit switches fir the top. I repaired the wire and restored service - of course with a new motor as well. Not saying yours is nit the motor. Just recognize that it might be something else.
BTW - the motor replacement can be done at home using Shipkillers guides.
Good luck
      07-17-2016, 04:04 PM   #11
rsutoratosu
Drives: Z4 3.0i
Mines been dead for 2 years, I would totally move it to the trunk and never look back whn I do mine..
-Roranji
      04-13-2017, 03:27 PM   #12
Diesel_d66
Drives: '07 MR
Finally found enough change between the cushions and a reputable shop (my local shop At Speed closed) to take in to replace the pump. look at this corroded crap.
Luckily the shop lets me bring in my parts. but the lines may need to be changed too. argh
      04-13-2017, 09:00 PM   #13
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Special place in hell reserved for the guy that decided to locate the pump next to the water drain
      04-16-2017, 10:46 PM   #14
StickMon
StickMon's Avatar
Drives: 2006 MR
Right next to the guy that designed the Vanos exhaust hub and the guy that didn't use a key on the plate with the camshaft splines, so that the bolts are stressed in shear and well, shear.
      04-17-2017, 10:58 AM   #15
Diesel_d66
Drives: '07 MR
Got the car back and took it for a drive this weekend with the nice weather. Man was it nice to be driving it again with the top down for the first time in a few months! almost worth the $2k!
The car was covered in pollen so I took to a touchless car wash and duct taped over the driver side top drain access. Should I be concerned about the passenger side drain as well, does that drain go near the pump or any of the top mechanics?
      04-17-2017, 11:11 AM   #16
arlovarri
Drives: e90 330i & 07 Z4
Two people to move the top back off the car, and the blue painters tape all along where the top meets the paint are the two most important parts of the job to remember. Also when removing the left side shelf tray support, finding the little plastic rivet in the middle top of the tray support took me a few minutes. The rest is pretty straightforward if you pay attention to all the guides out there. I am way too tall to get into the trunk but was able to reach the bolts just by leaning in and working above/behind my head. If you have any lower back problems take some ibuprofen first.
      04-17-2017, 11:47 AM   #17
dc_wright
dc_wright's Avatar
249
You've got to take care of both drains. The passenger side drain funnel overflow won't hurt anything from the top mechanism but it will get your rear speaker wet and ruin the speaker and potentially the audio amp. There's really no place in the rear area of the passenger compartment where a water dousing won't find something bad and expensive.
The touchless car washes are even worse than a regular wash because of the higher volume of water they use. There's really no car wash that doesn't have some negative effect on a vert car. In either a touchless or a conventional car wash the chemicals (soap & wax) are designed for automotive paints, not top canvas, and they can be caustic to the cloth materials.
Top Down 365
      04-19-2017, 09:22 AM   #18
Diesel_d66
Drives: '07 MR
wow. i had no idea about the potential speaker damage due to water overflow on the passenger side. and looks like i need to pick up some car wash essentials and wash the car myself. thanks for the info!
.... and the potential for speaker damange! that guy should be kicked in nuts!
      04-19-2017, 10:33 AM   #19
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Might as well throw in the guy that designed the bearings, oil system.
Salty
      04-24-2017, 01:45 PM   #20
StickMon
StickMon's Avatar
Drives: 2006 MR
I think they have a justification for that.
They wanted to keep the crank short, and therefore the block, and therefore also save weight for racing.
Fine if you have a crew that's going to pull the motor and rebuild it every few races.
Not so fine for a street machine.
