05-27-2016, 03:05 PM | #1 |
Rep 847
ECU flash
I am a bit lost on this one so any help would be much appreciated!
My 06 M roady recently got a REJECT from annual smog inspection in MA. I had to take it to one of their special inspection units (which they call motorist assistance center) and was told that the ECU has a European tune and must be flashed. The guy gave me a printout of the scan results that showed EOBD instead of OBDII, which is apparently the issue. I called two dealers in the Boston area. One of them had no idea what I was talking about, and the other one said they can flash the software but don't guarantee that "it would take," and that I may need a new ECU if mine is European (which makes no sense). Figure this forum has way more collective knowledge than the typical stealer. Has anyone has this issue before? Last edited by Spaceman Spiff; 05-27-2016 at 03:39 PM.. |
05-27-2016, 07:15 PM | #2 |
Rep 204
Someone else ran into this problem this year too. If you go back a page or 2 you should find it. Makes me wonder if there was a mix up with DME's at the factory.
05-27-2016, 07:20 PM | #3 |
Rep 350
I would think the biggest issue wouldn't be the tune. It would be that if your car is european it would be missing some cats. That being said, if it has a euro dme who cars if it meets the smog test requirements. What do they do with cars that are imported from another country?
05-27-2016, 07:23 PM | #4 |
Rep 2,782
Active Autowerkes or ESS should be able to help you out.
05-27-2016, 09:20 PM | #5 |
Rep 847
Yeah I was able to find that thread. Hope mine is simply a case of the previous owner having installed the EU tune, rather than a whole new ECU. Funny thing is, it passed the test last year, but not this year.
05-27-2016, 09:22 PM | #6 | |
Rep 204
05-27-2016, 09:23 PM | #7 | |
Rep 847
05-27-2016, 09:24 PM | #8 |
Rep 847
05-27-2016, 09:26 PM | #9 |
Rep 11,667
There is no different Euro DME, they're all the same.
Software is the only difference. Check with one of the tuners as Pokey mentioned. They may even find your car, if they track tunes by VIN.
06-20-2016, 01:13 PM | #10 |
Rep 847
Update #1 for those who may find themselves in a similar situation: After looking into all available options, I had it flashed at the dealer, costing 2hrs of labor (consistent between dealers in NY and Boston). Interestingly, most suburban dealers either didn't know what I was even talking about, or told me they don't do this kind of work anymore.
Will be driving up to Boston next week to get it reinspected. Will give another update then. |
