      08-10-2013, 11:15 AM   #45
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Drives: ‘06 Z4MR, ‘20 X7, ‘22 M4x
Originally Posted by dbarton62 View Post
Besides the weight savings and the cleaner engine bay are there any performance gains HP wise with removing the SAP and EGR?
It's more likely a negative effect actually, I'm not sure about the system in the S54 but EGR is critical for NOx emissions and keeping combustion temps down. Maybe somebody here who knows the conditions (RPM, load, temp, etc.) when the EGR is active on these cars could chime in.
I don't think power would meaningfully change in either direction, but increased temps likely aren't good for your engine oil and exhaust valves. The weight savings are negligible, it seems this mod is a trade between a "clean" engine bay and failing smog at the least (in California anyway).
      08-10-2013, 11:25 AM   #46
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Well for me, I have Euro catless headers and a catless section 1. So I'm pretty sure my NOx emissions are off the scales, and my overall temps are down because I don't have cats.
      08-10-2013, 11:32 AM   #47
ZStig
279
Here we go: you need a 10mm socket for the engine block connection, and 13mm socket for the bracket connection. 10 minute job max.
Oddly, the Lang Racing piece comes with bolts, instead of nuts. So... I just re-used the stock nuts. Maybe there's a way to remove the bolts protruding from the engine block, but I didn't think it was worth the risk of stripping the thread.
NO CEL. Here's the explanation from ECS:
"The SAP in a vehicle injects air into the manifold to recreate a lean condition which causes the catalytic converters to raise in temperature until they are at optimum efficiency. If running exhaust headers this system is not necessary"
Weight Saved: 4.25lbs or 1935 grams
      08-10-2013, 11:42 AM   #48
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
Fair enough if smog isnt a concern however, it isn't the cats that cause an increase in combustion temps. My understanding is that the exhaust gases that get re-routed back into the combustion chamber don't ignite like A/F does, which creates the cooling effect.
      08-10-2013, 11:55 AM   #49
ZStig
279
I think this thing just pumps air into the exhaust chamber, I don't think re-routing hot air cools anything down, and I don't think this secondary air pump grabs anything but ambient air. I could be wrong, I'm just going by the ECS product description
      08-10-2013, 12:21 PM   #50
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6158
The function of the SAP is as you describe, it helps to warm up the cats on a cold start. This is a different function than what EGR does. I'm not sure if any of the hardware for the two systems in shared, as I said earlier I don't know the specifics of the system on the S54. I just saw an earlier post about an EGR delete and it raised my eyebrow. I would be wary of messing with this outside of race applications. I have no idea how FI on a car like yours might play into it either.
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
      08-10-2013, 01:24 PM   #51
ZStig
279
Good questions. I'm assuming this is just a secondary air pump to pump air into the cats
      08-10-2013, 10:30 PM   #52
StickMon
StickMon's Avatar
Drives: 2006 MR
It's not an EGR because there's no connection back to the intake.
Where is the EGR?
      08-19-2013, 01:22 PM   #53
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Got a CEL after the second cold start...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      08-19-2013, 01:34 PM   #54
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
So it might be the ESS software that delete the CEL than. I've started the car last winter at -20 degrees Celsius and never had a CEL and idle was perfect.
      08-19-2013, 03:51 PM   #55
ZStig
279
Hmm. It might be the ESS software indeed that negates the CEL. I havent driven recently, will report in a week after some more cold starts
      08-20-2013, 09:31 AM   #56
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
ESS - Software
Anyone contact Roman to find out if this is the case and then we can all deleted it
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
      08-28-2013, 10:46 PM   #57
ZStig
279
after many cold starts, I'm pleased to report no CEL.
Yes, I have ESS supercharger software
      03-02-2015, 05:31 PM   #58
ZStig
279
Update. I do get a check engine light every month or 2, until I reset it again with a cheap ebay tool
      03-04-2015, 04:51 PM   #59
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
Ugh. The CEL is a deal breaker for me. I'll have to wait until I actually install my tune. The BMW block off plate is great for Cali guys because you don't want anything fancy setting off the visual during a smog check.
CSL headers*Euro cats*Arqray exhaust*DKF hangers*Evolve Tune*Genuine CSL rims*10mm Macht Schnell front spacers*modified Hamann bumper*Tekarbon 2X2 CF spoiler*Turner CF grills*AS SSK*KWV3*OEM Strut bar*Rogue RSM*Polyurethane anti-roll bar bushings*Deka ETX30L battery*Nav Video module*front & rear cameras*Ipod module*stubby antenna*R-Dash LED license lights*LED Ziza interior lights
      03-07-2015, 12:55 PM   #60
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
I messaged evolve about removing the code...they said just need the exact code and they can turn it off
I'll be pulling off the pump this spring, and then updating the tune
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      03-10-2015, 12:39 AM   #61
Jumbosock
Jumbosock's Avatar
76
Removing the code with a tune is only good if all the sensors remain in their readiness state for smog checks.
