      03-23-2015, 08:30 PM   #1
koruptor
koruptor's Avatar
31
Drives: 2008 Z4 3.0si Coupe
How to remove trim...
Hi guys,
I tried removing the driver's side trim panel and chipped an edge off of it. It's minor, but noticeable.
Are there detailed instructions on removing it? I took a picture of this retaining pin, but am not sure how to get the trim out.
I have the service manual, and it says to use special tool (looks like a plastic card) to shimmy it out of there. I tried with a trim removal tool and, well, chipped it from too much leverage.
I did a search for this and found only one small reference to the pins here.
Here are pics of the first pin I couldn't get out:
2008 Z4 3.0si Coupe
      03-24-2015, 11:17 AM   #2
Steeler
Steeler's Avatar
2428
I used a couple of plastic knives by sliding them between the trim panel and the dash.
Slowly push the knife in until you can pry the trim away from the dash.
It will pop out, you will likely lose a couple of the retaining clips in the process.
      03-24-2015, 11:19 AM   #3
koruptor
koruptor's Avatar
31
Cool. Thanks for the tip!
2008 Z4 3.0si Coupe
      04-23-2015, 05:56 PM   #4
JCF
Drives: 07 Z4 M Coupe
Careful using a butter knife. It can still scratch things. Drivers side trim is easier to remove if you remove the vent to the left of the trim.
Spend $20 and get a set of plastic trim removal tools. Worth every penny.
I just finished covering my dash trim with CF dinoc. Planning on tackling the center console this weekend.
      04-23-2015, 06:31 PM   #5
Steeler
Steeler's Avatar
2428
Nice job
      04-24-2015, 12:11 PM   #6
koruptor
koruptor's Avatar
31
Had some help, but I was able to get the trim off without using a butter knife. The hardest part turned out to be the center air vent, but once you get that off it's a breeze. I plastidipped the left and right pieces. Like you, I'll be doing the center trim soon. Will follow with pics when complete!
2008 Z4 3.0si Coupe
      04-24-2015, 02:26 PM   #7
JCF
At the end of this thread over on bimmerforums are some pictures in PDFS on how to remove the center trim. HIGHLY recommend taking a look. It covers everything with pictures and makes it a heck of a lot easier. Don't be intimidated by the number of steps. It's not difficult, just takes a while and yes you need to remove the rear console.
http://www.bimmerforums.com/forum/sh...Dashboard-Trim
      04-24-2015, 02:42 PM   #8
koruptor
koruptor's Avatar
31
Thanks for the link!
2008 Z4 3.0si Coupe
      04-24-2015, 03:40 PM   #9
GP20
3M di-noc is not a good option for wrapping interior trims because it's not as flexible. 3M 1080 is much better and easier to use.
I just wrapped my steering spoke trims with matte black 3M 1080 film and it came out perfect.
      05-31-2015, 10:07 AM   #10
koruptor
koruptor's Avatar
31
Finally dipped the center console trim yesterday. Removing the center console and storage compartment was actually pretty easy, though it took a lot of time.
Sorry for the crappy cell phone pic:
2008 Z4 3.0si Coupe
