08-05-2015, 01:20 PM | #1 |
Rep 247
Windshield moulding coming unglued
Need some advice, the driver side window gasket is peeling away from the car...what can I use to fix this? reglue it?
thanks for the help..
| 2008 Interlagos Blue Z4MC | | AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust | |
08-05-2015, 01:23 PM | #2 |
636
Rep 3,124
Silicone calk?
You want to use something you can easily peel off when the weatherstripping inevitably needs to be replaced.
08-05-2015, 04:00 PM | #3 |
Rep 515
Mine started to do the same late last year and was considering some type of adhesive until I was fortunate enough to have a decent sized rock kicked up by a truck in front of me that resulted in nice 9" long crack that outlined the inner and bottom edges of teh passenger side visor. Now I have new front glass.
08-05-2015, 08:34 PM | #4 |
Rep 247
I was thinking silicone..just wasn't sure..
08-12-2015, 01:42 PM | #6 |
Rep 2,866
08-12-2015, 02:26 PM | #7 |
636
Rep 3,124
Definitely not.
Old one pops right out, new one pops right in. Some have had trouble getting it to go in and stay in. I think there must be slight variation in the position of windshields versus the surrounding bodywork. I got lucky. Mine snapped into place with no glue needed and has been set for at least 2 years.
08-12-2015, 02:28 PM | #8 |
Rep 11,667
^ whs
100% you do not have to do the windshield. I have done this trim and it's very straight forward to replace. The part is inexpensive as well, IIRC it was in the $70 range.
08-12-2015, 03:02 PM | #9 |
Rep 400
08-13-2015, 01:35 PM | #10 |
Rep 874
That's not what I heard. I had my roof wrapped and they managed to damage that molding so they had to replace it. They in return had a glaser replace it and the glaser had to remove the windshield because the molding was wedged between the windshield and a-pillar. I assume they know what they're talking about since they change windshields all day long. I'm not the one paying for it so I don't care. Got a new windshield also since the old one broke when they removed it.
08-13-2015, 03:53 PM | #11 |
Rep 187
It's true that it's sometimes possible, but it's sort of a matter of luck. The moulding has a kind of hook on it, you need to push it down far enough that the hook will manage to slide in behind the glass and catch; locking it in place. The front outer surface grabs the front of the glass, the hook grabs the back side. If you can't get it pushed in just right and the hook doesn't grab hold on the back, glass is coming out. If you're lucky or skilled enough and it snaps together around the back of the windshield, glass can stay.
If the glass comes out they can easily install the moulding onto the glass then place it into the car as a whole. This was all explained to me by the glass shop who shares the building with my friend's indy BMW exclusive shop, they've worked on many of these modern BMW trim pieces and always try it without removing the windshield first.
1990 332i 5 speed (OBD2 S52 Swap)
2018 VW Golf R (6spd manual/copper orange metallic) 2008 KTM SuperDuke 990 2007 Z4M Coupe (#1026/1815) SOLD |
