      09-06-2011, 04:55 AM   #1
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
Hazard Lights
My hazard lights are ON all the time if I switch to DIM or Headlight, and they blink when I use my right/left indicators.
All working fine and normally, but I would like to inverse that and make it light up only when using right/left indicators.
Another things, my daytime ring lights are ON all the time, i would like them to be on only when switch at DIM or Headlight.
Please help, any ideas?
      09-07-2011, 03:25 AM   #2
asirvr4
Oman
38
Anyone understood what I mean?
      09-10-2011, 09:11 AM   #3
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
here in the states, the ambers below the headlamps are on whenever the low beams or parking lights are activated. there is a possibility that you can have your SZL (light control module) reprogrammed for ECE specs, which would force the ambers off untill you use a turn indicator or the hazard switch. i belive starscream has a thread for just this type of thing.
the inner halo ring DRL can be turned off by a dealer. the car has to be hooked up to either their ProgMan or their ISIS through the car's personal settings. from there it's also possible to adjust the one touch turn indicators, sensitivity of the light sensor that activates the headlamps, key memory settings, and few other features.
and welcome to zpost!
