      08-15-2011, 08:42 PM   #1
Drives: M2 Comp
DIY - Secure the loose Windshield Washer bottle
I was in the middle of a bunch of things on the weekend.
While I had things apart, I decided to secure the washer bottle a bit better.
I found two issues.
1. there is only one screw that holds the entire thing in place.
2. the socket at the bottom of the tank was very loose fitting.
I did two things;
1. added some hi-density expanded foam at the bottom socket.
2. used a big zip tie around the entire tank to secure it.
End result; the tank is solid as a rock.
The pics.....
At the left arrow, I cut a small notch to keep the zip tie up.
At the right arrow, there is already a small notch in the black shield in a perfect spot.
      08-15-2011, 09:11 PM   #2
F360C
Drives: E86 S54
Awesome!
Ps... please post updated pics of your car!
07 Z4 M Coupe AW/IR
      08-15-2011, 09:18 PM   #3
Drives: M2 Comp
too soon.... not done playing yet
      08-15-2011, 09:31 PM   #4
F360C
Drives: E86 S54
I am no better... I still have to go out and take some pictures with my inTgr8r/APR front splitter.
07 Z4 M Coupe AW/IR
      08-15-2011, 11:48 PM   #5
r4gs
Viper Driver
Singapore
36
Drives: F-16
neat diy, thanks for making the effort! i've noticed how loose fitting the windshield washer bottle itself is in the engine compartment too. figures i don't even use the windshield washer system (for fear the front headlamp washers pop up and the tabs get blown away in the slipstream).
      08-16-2011, 06:43 AM   #6
Drives: M2 Comp
You can just pull the fuse on the headlamp washer.
It's a separate circuit.
You can see in one of the above pics, i stripped out the headlamp washer system as well.
