11-09-2015, 04:41 PM | #1 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
My alignment specs
I have had a few people ask so I thought I would share, this alignment was done after my H&R coilovers went on.
A few things to note, I do not have camber plates, all I have is alignment pins removed and the Turner Motorsport Camber kit (same as E36) Also the units below after the degrees are in minutes and seconds (not decimal as most are use to seeing), so I have converted those as well. I am aware that the specs are not 100% matching, however considering the mileage on my car, the sum of all the original components, and the 2+hours that went in to doing it while I was sitting in the car, I was very happy with the results. Your opinions/thoughts are welcome. Converted camber measurements to decimal degrees: Front Left Camber 3.38 Front Right Camber 3.33 Rear Left Camber 3.10 Rear Right Camber 3.11 If you would like to convert other measurements here is the calculator I used. http://www.rapidtables.com/convert/n...to-degrees.htm
E60 ///M5 - (6 Speed) Silverstone Metallic/Black F06 640iX - Tanzanite Blue/Amaro Brown K66 ///M1000RR - Competition |
11-10-2015, 09:56 AM | #3 |
Commander
221
Rep 850
I wanted it to be more on the aggressive side, and I really love the look. Plus I wanted to get as little rub as possible on the inner fender without having to roll them. As far as tire wear I always get directional tires and just end up flipping inside to outside/ left to right so they keep wearing evenly.
11-10-2015, 05:59 PM | #4 |
Rep 874
Ok, I was wondering since too much camber in the rear can cause even more oversteer. But if you're considering rub also I can see the point of quite a bit of camber.
11-11-2015, 04:56 PM | #5 |
Rep 1,031
That is a lot of camber in the front for not having camber plates. I was getting 2.9 in the front and almost at the max for the camber plate. Same for rear that is a lot, do you have the adjustable control arms? Bet its a fun ride though :P
11-12-2015, 06:37 AM | #6 |
Commander
221
Rep 850
Everything else is stock suspension-wise other than pins pulled, camber bolt kit and the coilovers. I do like the ride though, soon I'll get some better rear tires so it doesn't break traction so easily, currently have RS-3s on the front but Ventus V12s on the rear
11-12-2015, 07:51 AM | #7 | |
Rep 1,031
11-12-2015, 08:22 AM | #8 | |
Rep 11,667
it will be hard to improve traction with that rear camber regardless of tires. Especially true at the track when you get on it after the apex.
11-12-2015, 08:28 AM | #9 | |
Rep 11,667
It makes a big difference on the design of the top nut on the damper shaft. Many coilovers top nut comes up against the rim of the opening, others (eg KW cs) the top nut passes under the lip allowing more adjustment of the camber plates. There are a couple of solutions to this, depending on the COs used. I don't recall what the KW v3 looks like.
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 11-12-2015 at 08:35 AM.. |
11-12-2015, 08:30 AM | #10 |
Commander
221
Rep 850
Good to know, I don't feel so badly now for having mismatched front/rear tires, yet still my goal is to get RS-3s on the back as well. They definitely run wider than the V12s so I'll have to watch out for the rear rubbing.
11-13-2015, 04:20 PM | #11 |
Rep 2,138
Drives: Me
I run -2.0 (both sides) of rear camber and I cannot get any more from the stock camber arms..
I have run -3.4 up front, but you WILL cord the inner 1/2 inch of tire with that much camber running on the street (inside 3000 miles). This happened to me. A brand new set of PSS's were shot. I normally run -2.5 up front and have for over four years with no abnormal wear.... The tipping point for harsh wear seems to be 'around' -2.7 to 2-9, and this will depend on other factors on your suspension. I have also found that putting a 100 or so pounds in the drivers seat for the alignment really does not accomplish much, in all actuality. If this was a track only monster that you trailered to each event or race, and you had YEARS of driving experience, you still might not be able to tell if you did or did not put the weight in the car for alignment. We did a simple experiment at the shop I go to a couple of years ago. We aligned my car. I drove around the block and we put the car up on the rack to check the alignment. The alignment had changed a slight amount. We did this six times. Each time the alignment values were different. So in all actuality, putting weight in the car for the alignment does not gain you anything. |
11-14-2015, 07:34 AM | #12 |
Rep 11,667
Interesting!
I'm running -3.2 front camber and haven't experienced the inner wear problem. I get there with camber plates not the camber kit at the bottom of the strut. I wonder if the added scrub radius with the kit is a contributing factor? I'm also running zero toe which definitely helps.
