      09-19-2015, 11:38 AM   #23
Bossdog
Bossdog's Avatar
27
Drives: 2006 Z4MR Imola Red
Originally Posted by babyfaby View Post
Hi,
This Shimmy is due to your control arm bushings. At the first brake application they take their place (causing shimmy and a steering wheel movement) and at the second one, the shimmy is not here anymore till you continue driving few miles and start braking again.
I experienced it and changed the bushings
Is 45K-ish odometer a typical replacement point for the FCAB? Or is there no Typical? Is it a DYI?
      09-23-2015, 09:14 PM   #24
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
I thought my front OEM rotors were warped....shimmy under braking....after reading MUCH info re this, I tried the counsel to brake VERY hard from 60 to near stop (not leaving the brakes engaged when stopped after the abrupt stop)....the shimmy went away; thought it was warped rotors....it was buildup on the rotors and pads that was addressed by harsh braking 2-3 X.
Racerbruce
