      05-18-2014, 11:55 PM   #1
SCHMOUPE
SCHMOUPE's Avatar
Drives: 2007 Z4M Coupe
2007 Z4M Coupe  [0.00]
SES Light - P0155
Hi gents,
need your help with a SES light that I am trying to diagnose. Background story, I have euro headers with the relocated secondary O2 sensors but recently the car threw a P0155 error (02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1).
My question to you fine folks:
1. Is the fix as simple as replacing the Lambda probe is this pic (part 1 or 2)?
2. If yes, which one is it? Or should I replace both? If so, what's the best place to order these? They seem to be very pricey
3. How easy is it to do it from the engine bay or under the car? Does it require any heatshield/pipe removal?
Any other advice is appreciated!
Thanks
The Raspinator
      05-20-2014, 08:28 AM   #2
SCHMOUPE
SCHMOUPE's Avatar
well, ordered 2 of these guys off Amazon.
http://www.amazon.com/Bosch-15168-Ox...ds=bosch+15168
215 shipped for two which is less than price of one at the dealer.
The Raspinator
      05-22-2014, 11:40 PM   #3
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
What's up bud.... I believe both pre-cat are the same length and the same sensor #. They are both very easy to change and you can do it without jacking up the car. I would replace the broken one for now. As far I know sensors either work or they don't.
Just a hint, I used a one of this ratchets, plus a 20 inch pipe over it which will make it easier for you to to lose and tight the O2 back in place. The longer the neck of the ratchet is the less force you need to use....right?
http://www.newegg.com/Product/Produc...140523043144:s
Make sure you have a nice cold beer next to while doing this... it enhances the feeling of fixing your own car, please it helps cut down the cursing
Have fun!
Jeff.
      05-23-2014, 04:16 PM   #4
SCHMOUPE
SCHMOUPE's Avatar
Have fun!
Jeff.
HAHAH so finally got everything together this morning and took a crack at it. I think finish to start it took me a bit over an hour. I jacked up the front end and it helped me a bit trying to put the new sensors in (not 100% necessary but makes life easier)
I ended up changing both and glad I did. Check out the carbon build up on this bad boy.... Reset the SES light and P0155 has not returned yet. Fingers crossed!
The Raspinator
