      05-17-2014, 09:14 AM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
Oil inside fuel injector receptacle?
While removing the injectors wire-harness, I found oil inside the connectors
Did that happen to you guys? if so how did you fix it? Thanks in advance.
      05-17-2014, 10:23 AM   #2
GuidoK
GuidoK's Avatar
10855
Drives: Z4 3.0i ESS TS2+
That is very strange because that can't get there by itself.
Are you sure it's not petrol?
If it's really oil some mechanic put it there, maybe to loosen the connectors more easily or fight off possible corrosion.
It is extremely unlikely that your ccv is venting so much oil it creeps up possible multiple leaking injectors (before someone suggests that )
      05-17-2014, 11:19 AM   #3
Beedub
old gas thats got trapped and funny colour?? stick a cotton bud their and feel its consistency
      05-17-2014, 11:19 AM   #4
rocky79
rocky79's Avatar
It's definetly Oil and was wondering if that happened to anyone.
      05-17-2014, 10:23 PM   #5
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
maybe its dielectric grease that got some soot in it. that would be pretty much the same color and consistency as oil.
weird
      05-18-2014, 12:10 AM   #6
StickMon
StickMon's Avatar
Drives: 2006 MR
My guess is it's some previous mechanic's voodoo substitute for dielectric grease.
That's a sealed connector. Epoxy on the inside, boot on the outside.
Nothing should be able to get into it from either end unless it was put there on purpose.
      05-22-2014, 07:45 AM   #7
rocky79
rocky79's Avatar
Thanks for the feedback.
I cleaned up the oil and going to see if it magically forms back I think that should be it.
