      05-13-2014, 08:22 AM   #1
3002 tii
3002 tii's Avatar
2285
Has Anyone Installed 12V Socket Receptacle in Trunk?
Just like title says, anyone install one in the trunk? Would like to install something like this
http://www.amazon.com/Marine-Grade-C...ket+receptacle
http://www.amazon.com/Blue-Sea-Syste...ket+receptacle
that way I can charge my accessories while on track (camera, GPS antenna, etc.). Also I was going to install directly onto battery but should I use a switched source instead?
Follow for latest mods
      05-13-2014, 03:20 PM   #2
SD ///M4
///Multiple
SD ///M4's Avatar
I don't need one in my trunk, but that dual-port USB socket looks like it would work really well mounted in the center under dash panel. I'm using a ProClip to mount my smartphone just to the right of the temperature knob and that would be a much cleaner install than having a 12V USB port plugged into the cigarette lighter socket.
I've already installed a garage door opener in that panel and it's wired to a switched hot source, so it would be a piece of cake to piggyback off those connections.
Thanks for the inspiration! If and when I do this I'll write up a DIY.
The Sedan: 2018 M3 | San Marino Blue | Black Full Merino Leather | CF Trim | M-DCT | ZCP | ED 7/18/18
The Roadster: 2006 Z4 | Interlagos Blue | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
      05-13-2014, 03:37 PM   #3
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Looks like a cool idea, interested to see where this goes.
What kind of switched connection would you be able to do from the trunk?
      05-13-2014, 08:08 PM   #4
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
I'm just about to do it.
Ron stygar did it, scroll way down this thread to see the wiring for the Z4
http://www.bimmerfest.com/forums/showthread.php?t=25528
You can pick up the switched lug so it turns off when turn off the ignition.
I ordered this outlet, after looking through all of the ones on Amazon. It feels like a pretty good quality piece.
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
You'll also want an inline fuse. Something small, probably 5 amps would do it.
      05-13-2014, 11:36 PM   #5
StickMon
StickMon's Avatar
Drives: 2006 MR
Go straight to the battery.
It's right there in a handy location, and you can lock the car and go grab a bite while your stuff's still charging.
      05-14-2014, 01:08 AM   #6
SD ///M4
///Multiple
SD ///M4's Avatar
I went with this one because it looks like I can mount it nearly flush with the center panel by using the knurled plastic nut, no need for the faceplate. I'll probably cut off the waterproof cap:
(click pic for link)
      05-14-2014, 11:54 AM   #7
jdoublehcubed
Mechanical Engineer
Sounds like a good way to kill your battery when you leave something on the charger by mistake.
      05-14-2014, 10:30 PM   #8
StickMon
StickMon's Avatar
Drives: 2006 MR
If you can kill your battery charging something via USB, you need a new battery.
      05-15-2014, 07:29 AM   #9
jdoublehcubed
Mechanical Engineer
you can pull up to an amp via USB, I don't think its unreasonable to think that could kill a battery if it was left to sit overnight, say 12 hours or so
