05-11-2014, 07:29 AM | #1 |
Rep 2,704
Oil temps
Wondering what oil temps others are getting during regular day to day driving
Mine get up to 210-220 on an 80 degree day. Is that normal? Can you guys who monitor that share your data??
05-11-2014, 09:15 AM | #2 |
1621
Rep 4,294
that would be degrees F, not sure, but mine sits pretty much in the center after taking about 10 minutes to warm up.
Powered by |
05-11-2014, 10:10 AM | #3 |
Rep 1,134
Drives: '07 M Roadster
210-220F is 98-104 C
05-12-2014, 05:43 PM | #5 |
Rep 2,704
Thanks guys
Looking more for a figure as shown on an analog guage More likely the supercharged guys have a guage My concern is I am running hot with the supercharger and I could use an oil cooler The water temp guage sits right where it should be. Are the oil and water temps comparable ie if the water temp guage is showing normal then 210-220 f is normal oil temp?
05-12-2014, 08:01 PM | #6 |
Rep 2,704
Google turned up this http://www.bobistheoilguy.com/motor-oil-101
Seems my temps are within normal limits
05-14-2014, 12:27 AM | #7 |
1621
Rep 4,294
hmm, i dont have water temp, only oil temp... ill have a look on my next hoon what the actual numbers are yep oil and water temp should be comparable.
Powered by |
05-14-2014, 07:50 AM | #8 |
Z4M CSL
31
Rep 173
I've seen 125C after a long (30-minute) track session at the 'Ring in 32C ambient.
That's about 258F and 90F respectively. M3 guys all see similar after track sessions, and general consensus was below 280F was fine.
05-14-2014, 10:22 AM | #9 |
Rep 2,704
Vanne and Sixspeed, good to know I am not concerned with my temps now.
I did see 230f last year during the Woodward Dream Cruise but that was in 10mph traffic cruising the strip.
05-15-2014, 09:11 AM | #10 |
///M-fanatic
193
Rep 3,885
Normally, my car runs around the 12-o-clock mark @ 210*F. On the track when it was still NA, I saw as high as 230-240*F. Now that it's supercharged, I'm hoping it's not too bad.
When I tracked my friend's bone stock E90 M3 one time, I also saw the same 230-240*F temps. These were all @ Laguna Seca, where it's pretty mild mind you. Ambient temps in the wintertimes are usually around 60*F, and summertimes only get up to 80*F if that. So if I were to run my car in a hotter or more humid place, I might run into overheating issues |
05-15-2014, 11:10 AM | #11 |
Rep 2,138
Drives: Me
Has anybody noticed that you all are comparing apples to oranges.
The original OP has an M54 with forced induction. The OP needs to talk to 'pokybritches' who does have an M54 with forced induction and an ///M. |
05-15-2014, 01:38 PM | #12 | |
1821
Rep 5,337
Now, the WATER TEMP that was mentioned by OP...Is it on the factory gauge, or is it on the factory diagnostic menu, or was it from a separate aftermarket gauge? Because the factory gauge is buffered. It will only show 3 states, cold, warmed up, and engine is about to go Chernobyl. If the needle is moving away from dead center toward "warm" it's already starting to overheat.
05-15-2014, 04:10 PM | #13 |
Rep 2,704
Hack,
Water temp gauge is factory and needle is rock steady at 12 o,clock once warmed up. Aftermarket oil temp,boost and AFR. The car is strictly summer driven and as such run Castrol Edge with Syntec 5W40 My main concern was that the temps I was running were too high and that the oil would be breaking down prematurely because of the FI but it seems well within limits, especially if the water temp is as stable as it is.
05-15-2014, 05:58 PM | #14 | |
1821
Rep 5,337
As for that water temp gauge, it's useless. Like I said, it's not likely to budge from dead center until the engine is already at the verge of self destruction. It's a dummy gauge, there's 3 operating points, cold, warmed up, and about to overheat. Anything between "cold" and "about to overheat" it'll stay dead center. For an accurate monitoring of your water temp you should put the instrument cluster into diagnostic mode, or have another aftermarket gauge hooked up.
05-15-2014, 07:56 PM | #15 |
Rep 2,547
If you have a Intravee II, you can display the coolant temperature in C or F, as well as max temp. It'll even record and display the max temp for the previous 17 trips when looking through the journal history.
05-15-2014, 08:20 PM | #16 |
Rep 2,704
[QUOTEFor an accurate monitoring of your water temp you should put the instrument cluster into diagnostic mode, or have another aftermarket gauge hooked up.[/QUOTE]
How do I put the cluster in diagnostic mode?
