      05-04-2014, 11:11 PM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
N52 3.0Si Valve cover Gasket
After reading few DIY's I am finally going to replace the valve cover gasket along with the valvtronic motor seal.
For those of you who have done it, I have 2 questions for you:
1-Did you have to re-learn the ECU after removing the valvtronic motor to replace the seal?
2-I noticed some DIY's insists on removing the battery negative terminal, Is it because they're afraid of shorting wires? or are there other reasons?
I hope the radio doesn't ask for a code after the battery terminal has been disconnected.
      05-05-2014, 12:24 AM   #2
SDCoupe
SDCoupe's Avatar
79
Drives: M Coupe
I don't think the radio will ask for a code after disconnecting the battery. It didn't when I disconnected my battery.
      05-05-2014, 03:44 PM   #3
rocky79
rocky79's Avatar
Great, thank you SDCoupe.
So does anyone know if you have to re-learn the ECU after removing the valvtronic motor?
Do I need to disconnect the negative terminal?
Thanks
