05-04-2014, 03:32 PM | #1 |
Rep 50
Finally : 06' Z4 3.0si Roadster
Hi,
With everyone advices, I finally bought this: I need to clean it a lot, but it should be a great car... 78 000 KM... Only thing, I need to align the car, but after putting the rear tires at 38 psi, it is much better... In fact, the car is going left-right when the road is bad... |
05-04-2014, 03:37 PM | #2 |
Rep 1,247
Run flats?
Does it have the run flats on it?
05-05-2014, 06:36 AM | #5 |
Rep 4,057
Congratulations!!
Dandy car!! Yes, dump the run-flats and the car will drive much better. An hour or so with the washmitt, soap, some wax and tire dressing and you will be turning heads all over town!
Huz-Z
05-05-2014, 07:28 AM | #7 |
Clueless
Rep 116
It all starts with an hour or so of detailing,,, then you look at your watch and its been 6 hours and you are still smiling!!
05-05-2014, 09:29 AM | #8 |
Rep 1,991
05-05-2014, 10:17 AM | #9 |
Rep 501
Drives: 2015 M4
I just installed Pilot Sport A/S 3's on my Z4 MR - I have this on my S4 too - although it's an all-season, it's ultra-high performance.
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
05-08-2014, 02:47 PM | #10 | |
Rep 273
As mentioned, the very stiff walls on the OEM runflats can make the car dart around, requiring a lot of steering corrections especially over bad pavement. Search for 'tramlining' and you'll find lots of info. Replacing the runflat tires will help a great deal, but as you've seen proper air pressure is a huge factor as well, and the front and rear use different settings. Mine came with almost new tires (OEM runflats) with 34 PSI all around and the tramlining was very bad. After setting the pressures to the recommended F/R numbers on the door sill plate, the improvement was night and day. Convertible weather ahead - get out there and have some fun! |
05-08-2014, 04:00 PM | #11 |
Rep 1,910
M-Speed,
Congratulations on your new car--it is a beauty! Regarding tires, if you want to stay with run-flats, consider the third-generation Bridgestone Potenza RE960AS Pole Position RFT. Before I put a set of these on my 2006 Z4 3.0i, the car could be downright scary on bad pavement. The third-generation Bridgestones, however, were a dramatic improvement. "Tramlining" was almost nonexistent, and the ride was noticeably less harsh. On the other hand, the softer sidewalls don't provide the same instantaneous turn-in as a normal run flat tire. I was more than happy with the trade-off. A fuller discussion of tramlining and these tires is available at http://www.zpost.com/forums/showthread.php?t=886446. Enjoy the new car! Rick F. |
05-16-2014, 12:06 AM | #16 |
636
Rep 3,124
More than I can say.
I got projectile pooed on by a pig while passing a livestock semi tonight. Windows and top down, 104°F. Luckily I saw it coming and swerved. It's all over the side of the car, but it didn't get inside, or in my face. But I get the last laugh. He's bacon by now. Nice ride!!
05-16-2014, 01:26 AM | #17 |
Rep 1,247
Do you know what exhaust tips those are by chance???
05-16-2014, 07:25 PM | #19 | |
Rep 4,057
05-17-2014, 10:44 PM | #21 |
Rep 1,247
I don't think so!
