      02-05-2014, 06:08 PM   #1
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Proper Spacer/Wheel Combo
Looking for the correct spacer for my 18x8.5 et47 front wheels with 235x45-18 tires that get a little inside rubbing on hard left turns. Currently using 10mm pieces.
Any suggestions?
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      02-06-2014, 12:34 AM   #2
m5m3mc
Drives: M-B C63
Any suggestions?
Consider this just a data point. On the OE front wheel a 235/45-18 PSS very lightly rubs inside at full lock using a 10mm spacer. Keep in mind the PSS is very wide in the tread.
      02-06-2014, 08:08 AM   #3
mikeo
Santa Fe Concorso
mikeo's Avatar
Suspension is stock. Ok, thanks m5m3mc. Which direction should I go with the spacers? I'm thinking I should try 5mm which are on hand.
      02-06-2014, 11:30 AM   #4
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
If you're rubbing on the inside using 10mm, wouldn't 12 or 15mm be a better choice to push the wheel more outboard than using 5mm to get closer to inboard?
      02-06-2014, 11:42 AM   #5
mikeo
Santa Fe Concorso
mikeo's Avatar
Yes, you're right. Been under the weather lately and haven't even pulled a wheel to see exactly where it's rubbing. I'll most likely have to order 12 or 15mm for the fix.
      02-06-2014, 01:21 PM   #6
m5m3mc
Drives: M-B C63
15mm will help a lot. I wouldn't bother with 12mm because you're already 5mm more to the inside than stock (47 vs 42). I spaced out about the tread width...it's most likely the section width that is the problem here and the comment I made was based on stock suspension also.
      02-06-2014, 01:28 PM   #7
mikeo
Santa Fe Concorso
mikeo's Avatar
Just ordered the 15mm. Thanks for your advice. ;-)
      02-19-2014, 08:56 PM   #8
mikeo
Santa Fe Concorso
mikeo's Avatar
LOL! Turns out the 235/45-18 fronts needed LESS spacer not more as they were rubbing on the outside. Threw on the 5mm set I had and it's fine. Anyone need a new set of never mounted 15mm at a killer price?
      02-19-2014, 11:38 PM   #9
m5m3mc
Drives: M-B C63
Hmmm...are you sure your front is ET47?
      02-20-2014, 08:48 AM   #10
mikeo
Santa Fe Concorso
mikeo's Avatar
Yes, et47. I think the problem was the staying with 45 instead of dropping down to 235/40. Just a tad too tall.
