      12-27-2013, 10:51 PM   #1
jeebus87
Drives: '11 atacama yellow Z4 35i
Need help: what size extended wheel bolts do I need??
I have these babies waiting for me in the garage:
I quickly realized that the OEM wheel bolts are too short. I need to find out what length bolts I need... does anyone know?? I have no idea...
      12-28-2013, 08:43 AM   #2
Beedub
if you not using spacers why do you need longer bolts??
      12-28-2013, 11:20 AM   #3
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
you dont need longer bolts if those are sportline wheels. if you are using spacers, add whatever spacer you have in mm to the bolt lenght
instagram: @ dubsesd
      12-28-2013, 01:00 PM   #4
jeebus87
Thanks for the replies. I didn't think longer bolts were necessary, but when threading the OEM bolts through the sportline wheels, the threads barely catch the grooves of the hub. I get maybe one turn and then the bolt is flush against the wheel.
      12-28-2013, 01:23 PM   #5
jeebus87
Well, what do you know. It was my error all along. Thank you for your help and making sure I checked everything twice. Wheels are going on now! Pics to come.
