      03-12-2013, 09:57 PM   #1
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
255 vs 265 Width on a non M
It's nearly time to purchase tires for my EC7s coming in. I've had both rear sizes recommended; 255/35/18 and 265/35/18 with diameters of 25.028" and 25.303" relative to those sizes. On a non-M would there be a potential issue with rubbing on the slightly larger size or would it be wise to play it safe with the smaller size? APEX suggested it could rub and I trust their judgement, but wanted to see if anyone had experience with these. Also, it will be lowered with Eibach Pro Kit springs and Bilstein HD dampers.
Thanks!
      03-13-2013, 10:18 AM   #2
3002 tii
3002 tii's Avatar
2286
Thanks!
What's your wheel size? What are you running in the fronts? I would only run 265 in the rear if you were running 235 front to keep the ride height same -- and that's assuming 235's up front won't rub.
Assuming your rim width is 8.5-9.5", stick with 255. May as well play it safe.
Follow for latest mods
      03-13-2013, 10:38 AM   #3
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
^ That is exactly right. Running 8.5 front and 9.5 rear. 235/40/18 on the front. 255 would be the safe bet. However, 265 would be nearly identical in tire diameter since a 235/40/18 is 25.402". To take it a step further, could go 225/40/18 on the front. Darn math.
      04-07-2013, 08:50 AM   #4
3002 tii
3002 tii's Avatar
2286
You have bigger risk of rubbing on fronts with 235 than 265's in the rear. What are the offsets?
      04-07-2013, 10:49 AM   #5
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
Went with 225 front and 255 rear and it turned out great. Still on stock springs but doesn't appear it will rub even when dropped an inch. Thrilled with these PSSs.
      04-07-2013, 01:12 PM   #6
snowmirage
Drives: 2003 BMW Z4 3.0i
Good to hear, I went with
225/35ZR-19 Front
and
265/30ZR-19 on the Rear
The rears are great, the fronts I think rub just a touch if I really push it, something like a speed bump near full lock.
When I get the next set I'm going to see if I may have some more room for a step up on the rear.
      04-30-2013, 01:04 AM   #7
Messiah9000
Drives: Z4 Coupe 3.0si Manual M-Pack
But has anyone tried the rear M size for non M-car (for example E86 3.0si)? 255/40R18 on a stock 18x8.5 non M-wheel. Any rubbing?
      04-30-2013, 05:07 AM   #8
McKoval
Poland
Drives: z4 3.0si 2006
I have the opposite - 255/35/18 on M style 224 rims on my 3.0si - wouldn't dare to try 255/40 on this rim as it's really close to rub the outer fenders.
Will be fitting my kw v2's sometime next week - probably will be hard to set it without rubbing.
2006 3.0si
      04-30-2013, 10:14 AM   #9
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
McKoval, could it be the offset of the 224 rear rims possibly? I'm running the same size tires with the APEX EC-7s and it fits like a glove. However, I'm running stock suspension so there's plenty of room. But even dropping it an inch it should tuck nicely.
      05-06-2013, 06:15 PM   #10
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: '17 C2, GTI, Z4 3.0si Racecar
Running 265/35-18 on 18x9.5" OZ square on our race car. Not rubbing lowered on TC Kline C/Os.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      05-06-2013, 08:56 PM   #11
ANUSTART
ANUSTART's Avatar
35
Drives: Z4
That is crazy! Did you need to do a fender roll on it? Very cool!
      05-07-2013, 09:31 AM   #12
CJW2OO4
CJW2OO4's Avatar
I ran a 255/40/18 winter tires on my Z4 3.0 si Coupe (type 203 i think) wheels. BTW I am lowered on coilovers so that may affect the camber which may prevent some rubbing.
