09-08-2011, 12:54 AM | #1 |
Rep 33
Center Storage Compartment - Light always on?
Hello -
My Z4 M Coupe's center storage compartment light stays on all of the time. Is this normal?
2007 BMW Z4 M Coupe / Black Sapphire Metallic
Advan RS-D / Michelin PSS Shrick 288/280 Cams / Multi-Angle Valves Fabspeed Headers |
09-08-2011, 01:00 AM | #2 |
Rep 2,866
No. Your switch is broken.
09-08-2011, 01:03 AM | #3 |
Rep 1,603
Drives: Imola Red Z4MC
^ Wow really? Mine has always been on since i bought the car last summer, i thought this was normal! Would something like this be covered under warranty? Or is there a simple fix?
///M - Some Mods 'N Stuff
09-08-2011, 01:05 AM | #4 |
Rep 2,866
It should be covered under warranty. The repair (replacing the switch) is fairly simple...do a "search". I believed I ran across someone posting a fix on here somewhere.
09-08-2011, 09:51 AM | #6 |
Rep 33
Thanks all.
09-08-2011, 10:03 AM | #7 |
Rep 12,565
If someone could post the fix, much appreciated. I have the same problem as well but I recall that for certain MY, they changed the design over. Jamie (starscream) noticed this when he installed my Intravee II.
09-08-2011, 10:21 AM | #8 |
Rep 1,001
Had the same problem with my 2007 and took 3 trips to the dealerships to get it fixed (under warranty). The first idiot dealership could not figured it out and told me that was normal to have the light ON as long as the key is in the ignition. They end up replacing the whole door assembly.
09-08-2011, 10:32 AM | #10 |
Rep 191
That's very likely the problem. I noticed that there is a switch at the bottom of the storage compartment that is actuated by a small plastic tab at the bottom of the lid. In my case you could clearly see where this tab had broken off.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
09-08-2011, 12:03 PM | #11 |
Rep 4,365
My tab got bent once and I had to manually bend it back to get the light to shut off. Definitely not supposed to stay on the whole time. The tab should be like a fin in the very middle of the door on the bottom of it.
09-08-2011, 12:14 PM | #12 |
Rep 1,603
ah man seems like theres always a problem lately, gonna look into it today after school and if i cant fix it myself i'll make an appointment at the stealers
09-08-2011, 01:06 PM | #14 |
Rep 30
I used a foam ear plug. wedge it in on top of the metal tab and close the door . plug compresses and close switch light goes out . cost $.01
09-08-2011, 11:47 PM | #15 |
Rep 2,866
You guys are right...it's most likely the tab that is broken - see the attached picture that I snatched from Bill's Web Space.
09-09-2011, 12:17 AM | #16 |
Rep 494
I feel like a moron, but I think mine has been broke since before I bought the car. lol
Will be taking it to the stealership soon.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit| |
09-09-2011, 03:47 PM | #17 |
Rep 191
Terrible design IMO
09-09-2011, 07:46 PM | #18 |
Rep 49
Mine has the broken tab problem and the dealer repaired it even though it was out of warranty but now it's on all the time again and the tab isn't damaged so I guess the switch has gone out. Agreed, bad design.
09-09-2011, 08:31 PM | #19 |
Rep 10,309
Drives: A///MERICAN!!!
Mine finally burnt out.
