      07-09-2023, 08:54 AM   #1
Marlymarl1
Drives: 2007 BMW Z4 Coupe 3.0si
Service Engine Soon Light just popped up
Hi Guys
Need a little help here…
I have a 2007 3.0si couple with 103,000 miles. Yesterday I got a Service Engine Soon Light that just popped up on the Dash. A brake light and DSC light that’s stuck on but brakes have been done. Took out the code reader and here’s what I got,
2A87 Exhaust Vanos, Mechanism
2A82 Vanos intake
2A98 Crankshaft-inlet camshaft correlation
2F7B Oil-pressure switch, plausibility
Any help would be greatly appreciated.
      07-15-2023, 03:00 PM   #2
DiscoJax
DiscoJax's Avatar
Drives: 2005 BMW Z4 3.0i
These codes indicate several issues related to the Variable Valve Timing (VVT) system, also known as VANOS on BMW vehicles. I'll explain each of these codes individually and provide potential fixes:
2A87 - Exhaust Vanos, Mechanism: This code suggests that there's a problem with the exhaust camshaft's ability to adjust valve timing. Possible causes may include a dirty or failing VANOS solenoid, low oil pressure, or a blocked oil passage. The most common fix is to replace the VANOS solenoid, but you should first try cleaning it. If the problem persists, you may need to inspect the oil pressure and passages.
2A82 - Vanos Intake: Similar to the previous code, this code relates to the intake camshaft's ability to adjust valve timing. The potential causes and fixes are the same as above.
2A98 - Crankshaft-inlet camshaft correlation: This code indicates that the correlation between the crankshaft and the inlet camshaft is outside the acceptable range, likely due to issues with the VANOS system as well. The VANOS solenoids or the timing chain might be at fault. Before replacing anything, try cleaning the solenoids. If the problem continues, a more thorough diagnosis may be necessary, potentially involving the timing chain.
2F7B - Oil-pressure switch, plausibility: This code means that the oil pressure switch is sending implausible signals. This could be due to a faulty oil pressure switch, wiring issues, or actual oil pressure problems. The oil pressure switch is usually the first thing to replace when this code appears, but you should also check the wiring and the actual oil pressure.
As for the stuck Brake and DSC lights, they could be related to the aforementioned issues (as these systems are interconnected), or there might be separate issues with the brake system sensors, ABS system, or even the wheel speed sensors. You may need to read out codes specifically related to the brake and stability control systems to diagnose this problem.
      01-05-2024, 09:10 AM   #3
Marlymarl1
Thanks for your reply. Are these things an expensive fix at dealer or local shop,if not doing the work myself?
      01-05-2024, 03:16 PM   #4
DiscoJax
DiscoJax's Avatar
The cost of fixing the issues associated with the error codes you're experiencing on your 2007 BMW 3.0si can vary widely depending on the specific nature of the problem and whether you choose a dealership or an independent shop for the repairs. Here's a rough estimate:
VANOS Solenoids (2A87, 2A82): Cleaning the VANOS solenoids, if that resolves the issue, is relatively inexpensive. However, if they need replacement, the cost can range from $250 to $500 per solenoid at an independent shop. BMW dealerships may charge more, potentially $400 to $700 per solenoid, including labor.
Camshaft Position Sensors (2A98): If the issue is with the camshaft sensors, replacing them typically costs between $200 and $400 per sensor at an independent shop and $300 to $600 per sensor at a dealership.
Timing Chain and Tensioner (2A98): This is likely the most expensive repair if needed. The cost can vary significantly, from around $1,500 to over $3,000, depending on the shop and the extent of the work required. Dealerships are usually on the higher end of this range.
Oil Pressure Switch/Sensor (2F7B): Replacing an oil pressure switch or sensor is usually not very expensive. Expect to pay between $100 and $200 at an independent shop and $200 to $300 at a dealership.
Remember, these are rough estimates and prices can vary based on your location, the exact nature of the problem, and the rates of the specific service provider. Additionally, if multiple issues are found, or if there are underlying problems that need to be addressed, the cost can increase.
If cost is a concern, getting a quote from both a dealership and an independent BMW specialist is a good strategy. Independent shops often offer more competitive pricing and many have expertise with BMW vehicles. However, a dealership might have more specialized diagnostic tools and direct access to OEM parts. Always ensure that whichever service provider you choose has a good reputation and experience with BMW vehicles.
