11-02-2021, 03:59 PM | #1 |
Rep 781
Couple of wheel/tire questions
The car, an 08/Z4MC has on it right now style 359, 19x9/ET31 with 245/35 Pilot sport A/S3 on the fronts and 19x10/ET25 with 275/35 on the rear.
There is no rubbing and it's a good looking set up. I will be spending a lot of time on the Hwy and the ride is a bit harsh on a rough road so was thinking about going with 18" wheels to gain that extra 1/2" of side wall. Do you think there will be a noticeable difference in the ride with extra 1/2" of rubber? Also, I noticed the dia. of the front tires are 654mm and the dia. of the rears is 675mm, isn't that difference going to show up in some detrimental way? I can't say I have noticed any problem with the difference if dia. but it just seemed to me the they should be the same ... or I could just be anal. Thanks
2008 E86 M coupe
11-02-2021, 05:04 PM | #2 |
Rep 2,866
The only thing I can think of having 245/35 on the front and 275/35 on the rear is how stability and traction control would behave at the extreme circumstances. But I guessed you would be OK if you haven't observed any nuances thus far?
Ride comfort is very subjective. I went from the stock 18" to my current 19" setup and didn't notice much of a difference in terms of harshness.
