      02-21-2021, 10:38 AM   #1
thielepr
Drives: 06 Z4M, 11 M3, 17 230i
Factory spring rates for the Z4M
Does anyone knows what’s the factory spring rates for the Z4M roadster? Normally that info is easy to find but I can’t find it any where
      02-21-2021, 04:37 PM   #2
maupineda
Drives: E86 Z4MC
If you search you will find the info here, from memory, fronts are 190-220, and rears are ~440.
      02-26-2021, 07:13 PM   #3
thielepr
That’s quite a difference between front and back
      02-27-2021, 06:23 AM   #4
maupineda
Drives: E86 Z4MC
Is due to the rear suspension design which places the spring midway the control arm effectively increasing the lever arm. As is it is very balanced in terms of ride frequencies.
You need a bit higher frequency at the rear to equalize the suspension motion as car goes over bumps, the rear wheels need to catch up with the fronts.
