      10-27-2020, 11:11 PM   #23
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Originally Posted by jhall1957 View Post
After 15 years of wheel to wheel racing(SE30 and SE46) Ive sold my race car and will be tracking for liesure my 2007 Z4MC which has big brakes, coilovers, fixed seats and harnesses and roll bar.
Currently it have Apex wheels with 265/40-18 rubber up front and 275/35-18 in the back. Looking for first hand experience with different "R' rated tires.
I recently went the other way and sold a similarly prepped Z4MC to race an e36. Tested a number of tires and hopefully can help. Was able to fit All of the below tires in 275/35/18 On all four corners with 18x9.5 wheels With just a little fender rolling and Track alignment on JRZ 2WNR. 3mm spacer up front to eliminate spring perch rub.
- Hoosier R7 / A7: DOT Slick - Probably overkill for a track day but if you want to set a PB and make use of your BBK, have fun. Pretty much done at around 15 heat cycles
- R888R: 100 TW - About 4 seconds off the pace of an R7 and can take damp/drying conditions when still has tread. Should last at least 10 track days or longer and should be very similar to the Toyo Slick you use in SE46 Personally don’t like this tire and always seemed to heatcycle out quickly.
- NT01: 100 TW - In my opinion, best bang for your buck. Doesn’t heat cycles as quickly as the R888R and about as fast as an 8HC Hoosier R7 when new
- BFG Rival: 200 TW - About 5 seconds off the pace of an R7 but wears very Slowly and performs well in wet and dry conditions. Great tire for mixed conditions, driving to/from track and/or instructing
Good Luck!
      10-28-2020, 07:29 AM   #24
jhall1957
Drives: SE 46
Good Luck!
Thanks but no need anymore. My buddy wrecked and totaled my track Z4MC. It was insured by Hagerty and all is well.
Buying a fully prepped E36 M3 race car.
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
      10-28-2020, 11:21 AM   #25
Barryb97
Drives: 2006 M coupe
Originally Posted by jmillet View Post
I've gone through several sets of Toyo R888s mounted on E46 M3 wheels. Recently switched to the Bridgestone R71R with good results.
Good to hear from you Jim. Missed you this season.
Barry
CDV delete, clutch stop, BMW pedals, Strongstrut bar, CF rad & coil cover, M3 reps, roundel under hood, Intravee II, air bag sticker delete, first aid storage, painted reflectors, headlight washer disable, Skyer CF front lip, Short shift kit, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings, TC Kline DA coilovers, PB big brake kit, Skyer CF rear spoiler and diffuser, oil pressure and water temp guages.
      11-08-2020, 05:45 PM   #26
jmillet
jmillet's Avatar
64
CD-19
Barry
COVID 19 kept me close to home this track season but am looking forward to the 2021 season.
Jim
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
eggman51198.50
