      01-25-2021, 09:14 PM   #1
TyzToyz
TyzToyz's Avatar
Drives: 2008 BMW Z4 3.0si
TPMS Question
I am wondering if my car came with the in tire (valve stem) type of TPM or the VSS type and how to verify this for sure. I am not even sure if it was optional as I have been finding conflicting statements on the interweb.
My car is a 2008 Z4 3.0si roadster (Canadian) that was purchased with aftermarket 19" wheels.
I am chasing the dreaded ATC, ABS, LTP warning lights (DSC) and want to rule out the simple stuff first.
Is there a module in the car that I can physically look at to determine which system my car came with, or were ALL 2007 and up Z's equipped with the same system (valve stem) regardless?
Tye
      01-26-2021, 10:23 PM   #2
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
In the states, 07+ came with tpms. My 06 does not have them.Good Luck!
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
David701567.00
      01-27-2021, 09:15 AM   #3
B328iC
Drives: 97 328iC, 2003 Z4
If you check your wheel speed sensors you might find out they are dirty , bad or loaded with rust. I cleaned mine and that problem went away.
kaybat125.50
      01-27-2021, 02:42 PM   #4
1stw0rldpr0blems
Drives: 2006 Z4MC
The 06's work off the vehicle speed sensor on each tire, 07+ has the pressure sensor on the valve stem of each tire. Your 08 will have the valve stem TPMS setup.
All cars sold in the United States from 07+ have a TPMS standard, its not optional.
*Edit* sorry just noticed you're in Canada, but you probably still have the valve stem sensor setup.
      01-27-2021, 08:09 PM   #5
TyzToyz
TyzToyz's Avatar
Thanks for the replies. Unfortunately the car was purchased by my father (RIP) originally and the car came with the aftermarket wheels it now has. I just inherited the car and live in another province, so it will need a thorough inspection before I can register it. I have no idea if these lights were on the whole time of his ownership or if it is something that just arose.
The car has just under 39,000 km and I have checked/cleaned the VSS sensors and checked the wiring/connections at each wheel and verified the reluctors were clean of debris.
In my searches, I read that the receiver module for the TPMS is somewhere in the transmission tunnel, close to the tail shaft.
Is there anyone that can confirm the actual location? Because I also read that some Canadian cars were offered as TPMS optional.
I am waiting for my scan tool to arrive so I can diagnose further.
Good ole internet.
Cheers,
Tye
      01-27-2021, 09:13 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Good ole internet.
Cheers,
Tye
The TPMS antennas are located behind the wheel well liners.
I believe the module itself is in the tunnel (not 100% on this)
AFIK all CDN cars from '07 on were mandated to have TPMS
On another note, they can be coded off, which gets rid of the dash light.
      01-27-2021, 11:47 PM   #7
TyzToyz
TyzToyz's Avatar
Can you please elaborate on coded off? Is this through the INPA tool I have been hearing about or just a code reader/scan tool?
Also, will this affect the traction control and ABS?
I am trying to get the lights off for the out of province inspection and do not need to create any further problems, however, if I can delete the TPMS and fix the other lights, I will be happy.
      01-28-2021, 04:13 AM   #8
maupineda
Drives: E86 Z4MC
Good ole internet.
Cheers,
Tye
My Z4M is a Canada car, and does not have TPMS sensors. It reads of off the ABS sensors to compare wheel speed and determine a low pressure situation.
You could check for the receiving antena behind the wheel liners, or if you have NCSExpert, look at the coding. I will post mine when I get to my computer
      01-28-2021, 09:41 AM   #9
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
What year is your car? The switch over date is 2007...so some '07 got the TPMS sensors and some '07 use ABS sensors.
      01-28-2021, 08:59 PM   #10
maupineda
Drives: E86 Z4MC
Mine is an 07, produced in April
These are the values in my Kombi module, and my monitor system works just fine.
KBUS_RDC - K-BUS TIRE PRESSURE CONTROL (RDC)
nicht_aktiv
AKUSTIK_RDC - TIRE PRESSURE CONTROL (RDC) WARNING GONG
aktiv
CAN_RDC - CAN-BUS TIRE PRESSURE CONTROL (RDC)
aktiv
As I understand, KBUS option is used when the sensors and antennas are present and send the signal to the KOMBI (Cluster), CAN option is when the signal is read through ABS sensor, and the KOMBI manages any warning.
the other option is just the chime to let the user know if a low tire pressure condition is detected (AKUSTIK_RDC ).
It would be very educational if someone with factory TPMS sensors can post their values for the parameters above.
EDIT: Just to reiterate, my values above are factory, my car DOES NOT have TPMS sensors in the wheel assemblies, and my monitoring system works.
inTgr8r2431.50
XMetal1136.00
      01-29-2021, 09:17 PM   #11
Reborn_
Drives: 2007 BMW Z4MC
07z4m with TPMS in wheel sensor system
From factory:
- KBUS_RDC - K-BUS TIRE PRESSURE CONTROL (RDC) - set to aktiv
- AKUSTIK_RDC - TIRE PRESSURE CONTROL (RDC) WARNING GONG - set to aktiv
- CAN_RDC - CAN-BUS TIRE PRESSURE CONTROL (RDC) - set to nicht_aktiv
I think you are correct maupineda.
Last edited by Reborn_; 01-31-2021 at 05:54 PM.. Reason: Checked my module file to verify CAN_RDC
maupineda455.50
      01-31-2021, 12:43 PM   #12
TyzToyz
TyzToyz's Avatar
I have not removed the tire to check for transmitters yet but found something odd while searching for easier solutions.
I was checking fuses, in location 42 & 43 for the DSC/ASC, someone had installed a 20A fuse in one location and a 40A in the other. I reinstalled 30A (factory recommended) in both locations.
Still waiting for my scanner/reader to arrive and I just ordered a cable for using INPA/NCSExpert.
Need to verify, if I disable TPMS, will this affect the traction control?
Tye
      01-31-2021, 01:13 PM   #13
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
Tye
I have disabled my 07 in-wheel TPMS system for a few years now.
Too much hassle with track wheels etc
Traction control works fine.
FB Group-- > fb.com/groups/z4group
FB Page-- > fb.com/Skyermotorsport
      01-31-2021, 05:29 PM   #14
Reborn_
Ditto.
      02-21-2021, 09:57 PM   #15
flyzipper
flyzipper's Avatar
Drives: 2008 M Coupe
RE: I am chasing the dreaded ATC, ABS, LTP warning lights (DSC) and want to rule out the simple stuff first.
Hoping it's something simple in your case.
When I had that collection of lights, it was post collision with 2 deer at highway speeds, which bent the steering rack (there's a wheel position sensor in that housing that feeds input to the stability systems).
My Canadian-origin 2008 M has TPMS that's based on relative wheel speeds.
      04-10-2021, 11:32 AM   #16
TyzToyz
TyzToyz's Avatar
I have struggled with this for too long and have sent my car to a reputable independent BMW specialist who will also perform the out of province inspection.
It seems the problem is not as easy of a fix as I was hoping. The shop has now spent 3 hours (at $140/hr) and has not found the problem. At what point do I pull the plug on this shop and where do I go from here???
The shop claims that the errors are triggered by the steering angle sensor and VSS. However, they claim that the actual sensors test fine???
Broken wire somewhere???
Tye
      04-12-2021, 08:35 PM   #17
TyzToyz
TyzToyz's Avatar
The shop phoned today and told me the bad news. Diagnosis is a bad ABS/DSC module.
Quote is $3100 plus labor and can only get it from BMW (Germany, at least 5 weeks).
Is there anywhere in North America to send this module? I think I was on 1 website where it stated that if it had certain codes, they could not repair. My codes consist of: 5DF0, 5DF1, 5DD0, 611E, 611B, 6128, 6127
Any feedback on this would be helpful.
Tye
      04-12-2021, 09:17 PM   #18
kaybat
kaybat's Avatar
'06 Z4M  [0.00]
https://modulemaster.com/products/bm...0e-abs-rebuild
      04-12-2021, 11:07 PM   #19
TyzToyz
TyzToyz's Avatar
Just came across this:
https://xemodex.ca/ca/abs-modules/
Anyone have any experience with either of these places?
Tye
      04-12-2021, 11:11 PM   #20
TyzToyz
TyzToyz's Avatar
Originally Posted by kaybat View Post
Thank-You Ken
kaybat125.50
