      05-24-2014, 01:17 PM   #1
rocky79
rocky79's Avatar
Drives: 2007 Z4 Coupe 3.0SI
Inlet-Vanos error after new valvetoronic Seal?
I have recently changed the valve cover gasket, the eccentric shaft seal and the valvtronic motor seal. After i put everything together.
I also performed the valvtronic relearn procedure...long story short, the car still starts rough and threw the check engine light:
Here is the error code I got:
Error: 1(1) Nr: 10882
2A82 Inlet-Vanos
(218) Moves with difficulty, jammed mechanically
P-Code: P0012 'A' Camshaft position-Timing over Retarded ( Bank1)
I looked around for that error code and it points to the Intake VANOS solenoid that needs to be replaced. Everything was running fine before, I am suspecting it's something with the valvetronic motor installation. Any idea how to remedy this situation?
      05-24-2014, 07:43 PM   #2
rocky79
rocky79's Avatar
Here is a snap shot from INPA.
      05-25-2014, 11:50 AM   #3
rocky79
rocky79's Avatar
Problem solved, It turned out that I mistakenly swaped the connector for the vanos inlet and exhaust solenoids...bad idea.
      05-25-2014, 12:14 PM   #4
JeffchaPz
JeffchaPz's Avatar
17
Drives: 2007 Z4M
Well.... thanks for sharing the knowledge.
