      09-08-2011, 12:54 AM   #1
taddpole
Drives: 2007 M Coupe
Center Storage Compartment - Light always on?
Hello -
My Z4 M Coupe's center storage compartment light stays on all of the time. Is this normal?
2007 BMW Z4 M Coupe / Black Sapphire Metallic
Advan RS-D / Michelin PSS
Shrick 288/280 Cams / Multi-Angle Valves
Fabspeed Headers
      09-08-2011, 01:00 AM   #2
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
No. Your switch is broken.
      09-08-2011, 01:03 AM   #3
VinnieAces
VinnieAces's Avatar
Drives: Imola Red Z4MC
2006 Z4 M Coupe  [8.00]
^ Wow really? Mine has always been on since i bought the car last summer, i thought this was normal! Would something like this be covered under warranty? Or is there a simple fix?
///M - Some Mods 'N Stuff
      09-08-2011, 01:05 AM   #4
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
It should be covered under warranty. The repair (replacing the switch) is fairly simple...do a "search". I believed I ran across someone posting a fix on here somewhere.
      09-08-2011, 09:10 AM   #5
wss4
Drives: 2008 Z4 M Coupe
Likely not the switch itself but instead a broken plastic tab on the door that activates the switch
      09-08-2011, 09:51 AM   #6
taddpole
Thanks all.
Fabspeed Headers
      09-08-2011, 10:03 AM   #7
2285
If someone could post the fix, much appreciated. I have the same problem as well but I recall that for certain MY, they changed the design over. Jamie (starscream) noticed this when he installed my Intravee II.
      09-08-2011, 10:21 AM   #8
Pheonix
2007 BMW/Z4MC  [0.00]
Had the same problem with my 2007 and took 3 trips to the dealerships to get it fixed (under warranty). The first idiot dealership could not figured it out and told me that was normal to have the light ON as long as the key is in the ignition. They end up replacing the whole door assembly.
      09-08-2011, 10:27 AM   #9
AlexTheMan
Drives: 2019 430i Gran Coupe
I have the same issue in my 2005 convertible. I just bought the car 2 months ago so I had no idea that the light should be off!!
      09-08-2011, 10:32 AM   #10
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
That's very likely the problem. I noticed that there is a switch at the bottom of the storage compartment that is actuated by a small plastic tab at the bottom of the lid. In my case you could clearly see where this tab had broken off.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
      09-08-2011, 12:03 PM   #11
Hawkeye
Hawkeye's Avatar
No_Country
2070
My tab got bent once and I had to manually bend it back to get the light to shut off. Definitely not supposed to stay on the whole time. The tab should be like a fin in the very middle of the door on the bottom of it.
      09-08-2011, 12:14 PM   #12
VinnieAces
VinnieAces's Avatar
ah man seems like theres always a problem lately, gonna look into it today after school and if i cant fix it myself i'll make an appointment at the stealers
      09-08-2011, 12:47 PM   #13
wss4
I used a small screw in place of the plastic tab for a while until I could bring the car to the dealership
      09-08-2011, 01:06 PM   #14
tommiegun57
tommiegun57's Avatar
Drives: Stratus Gray z4 i 07
I used a foam ear plug. wedge it in on top of the metal tab and close the door . plug compresses and close switch light goes out . cost $.01
      09-08-2011, 11:47 PM   #15
XMetal
XMetal's Avatar
2018 Audi S3  [0.00]
2004 X5  [8.50]
You guys are right...it's most likely the tab that is broken - see the attached picture that I snatched from Bill's Web Space.
      09-09-2011, 12:17 AM   #16
jdl1pt
Drives: Z4M coupe 2007 IL Blue
I feel like a moron, but I think mine has been broke since before I bought the car. lol
Will be taking it to the stealership soon.
|OEM Strut bar|ZHP Knob lighted|RPI Scoop|Zeckhausen Modified CDV|DIY Clutch Stop|Camber shim kit|
      09-09-2011, 03:47 PM   #17
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Terrible design IMO
      09-09-2011, 07:46 PM   #18
gigtime
gigtime's Avatar
Drives: 2003 Z4 2.5i
Mine has the broken tab problem and the dealer repaired it even though it was out of warranty but now it's on all the time again and the tab isn't damaged so I guess the switch has gone out. Agreed, bad design.
      09-09-2011, 08:31 PM   #19
BTM
Drives: A///MERICAN!!!
Mine finally burnt out.
      05-22-2014, 09:13 PM   #20
mazdaspd96
Drives: 2013 CX5
Could you please post pics of your homemade reparation? THanx
