      01-19-2014, 04:09 PM   #1
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
25mm spacer?
Thought to post here also:
I got the KW V3 and I am in the middle of the installation. Got the front coilovers installed but when I tried to mount the wheels the wheel/tire hits the suspension so obvious that I can't even make the wheel come near the hub.
Measured the space and its about 25mm between wheel and hub if I leave 10mm between inner wheel/tire to suspension.
Should I really get a 25mm spacer? or 20mm? or what?
How about the rears? will I need?
Note my wheel/tire setup:
Apex Arc-8 size/offset:
F 18 x 9 ET42
R 18 x 10 ET25
Tire:
Front: 245-40-R18
Rear: 275-35-R18
Original thread:
http://www.zpost.com/forums/showthread.php?t=894677
      01-20-2014, 08:17 AM   #2
asirvr4
Oman
38
ordered the 25mm for front and 5mm for the rear.
will update..!
      01-20-2014, 09:01 AM   #3
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6336
25 up front will rub like crazy and stick out
instagram: @ dubsesd
      01-21-2014, 06:48 AM   #4
asirvr4
Oman
38
You mean it will rub with the fenders? Even if I max out the camber?
I guess will do some fender rolling if it does
