      01-18-2014, 02:09 PM   #1
E85BMW
E85BMW's Avatar
Drives: 2006 M Roadster
Run-Flat's vs. Non Run-Flat's
Good afternoon everyone,
I tried searching the forums for an answer, but I don't think I got the exact answer I was looking for. I'll admit I'm not very knowledgeable in terms of tires, which is why I'm asking in the first place.
So, my car has the Sport Package equipped and came OEM with run-flat tires and that's all I've been using since I've had the car. Now, I'm thinking about switching to non run-flat tires. My question is, are there any adverse effects to using non run-flat's when the vehicle came equipped with Run Flat's?
Thanks.
      01-18-2014, 06:43 PM   #2
newbizie
newbizie's Avatar
Drives: 05 Z4 3.0i
I switched to non run flats and I couldn't be happier there shouldn't be any negative effects I'm pretty sure they only used run flats in the first place was because there is no spare
      01-18-2014, 06:49 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
There are "better" runflats out than a few years ago.
That said, I replace the rfts on my DD with Pilot Sport A/S tires. Couldn't be happier. Not quite as sticky as the Super
Sports but longer wear warranty and happier in very cold/wet weather. Very good in cold/wet, darn good in warmer weather too.
Choice of course depends on requirements (type of driving, conditions, etc.).
As noted, make sure you have a tire plug kit and mini-inflation pump, and/or the ///M mobility kit (or similar) is
N case of a flat. Obviously you can't drive on a regular tire when flat. AAA towing isn't a bad option either unless you're in the sticks somewhere (middle of Nevada, etc.).
      01-18-2014, 11:24 PM   #4
StickMon
StickMon's Avatar
Drives: 2006 MR
I'm about to go the other way, as much as I hate to.
Got stuck once on a busy freeway.
Hole in the sidewall. ///M mobility kit useless.
Dark. Everybody going by at 80+ mph, and people in SoCal often drive with 2 wheels on the shoulder.
I had to pull beyond the shoulder into the mud ditch and wait for over an hour for a tow.
That experience coupled with the fact that 3-4 times a month I'm out in the middle of the Mojave in the middle of the night leaves me little choice.
There are some apparently nice ones to be had, at $400+ each.
      01-18-2014, 11:51 PM   #5
wolfman1807
Clueless
wolfman1807's Avatar
Drives: 2003 Z4 3.0i SMG sport/premium
This is why living in North Dakota I have stuck to run flats. I would rather have a smoother running tire but cant take the chance on getting stuck out in nowhere in the Badlands and waiting for a friend with a tow truck!
      01-19-2014, 02:09 AM   #6
Finnegan
Finnegan's Avatar
Really good reasons to go the other way. Michellin makes some nice Pilot Sports in RFT. I had Bridgestone RE050As on my DD, and while they where not as nice as the Pilot Sport A/S or the Pilot Super Sport non RFT they were reasonably comfortable, not too noisy, and the stiff sidewall helped with turn in IMO. They were a whole world away from the RFTs I had back in 07. Man, those were harsh, loud, and "hard" and did not grip all that well.
      01-19-2014, 06:31 AM   #7
E85BMW
E85BMW's Avatar
Thanks everyone!
Tags
run flat oem, run-flat
